BT.com
Wishlist
LG Electronics 32LS33A 32" 1920x1080 9ms HDMI LED Large Format Display
Delivery
Standard Due date unavailable
The industry leading panel featuring a Direct-LED back light creates stylishly slim monitors designed to fit perfectly into narrow spaces in retail shops while ensuring high energy efficiency. SuperSign embedded player with RJ45 interface allows easy content transfer and control via network.
LED-backlit LCD flat panel display
Diagonal Class
32"
Diagonal Size
31.55 in
Commercial Use
Yes - digital signage
Titanium metallic
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
HDMI
HDMI Ports Qty
1 ports
LAN
PC Interface
VGA (HD-15)
HDCP Compatible
IPS
LCD Backlight Technology
LED backlight - direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
Speakers not included
USB
Remote Control
Standard remote
Voltage
Energy Class
Class B
Power Consumption (On mode)
45 W
Energy Consumption per Year
65 kWh
73.1 cm
5.6 kg
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Energy Class
Class B
45 W
65 kWh
Diagonal Class
32"
Diagonal Size
31.55 in
Commercial Use
TV Tuner
No tuner
Sensors
Temperature sensor
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Modes
Portrait mode, landscape mode
Dimensions
Without stand
73.1 cm
5.6 kg
Enclosure Colour
Titanium metallic
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Image Contrast Ratio
1200:1
Dynamic Contrast Ratio
500000:1
Brightness
300 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
9 ms
Stands & Mounts
Flat Panel Mount Interface
200 x 200 mm
Media Player
USB Port
Yes , 1 ports
Remote Control
Standard remote
Audio System
Audio Controls
Sound mode
Speaker System
External Speakers Amplifier Power (Total)
20 Watt
Balance control, Clear Voice II technology
Network & Internet Multimedia
LAN
LAN Protocol
Ethernet
Connector Type
HDMI input - rear , VGA input - rear , Serial input - side , Network - rear , USB - side , Serial output - side , Speakers output - rear , Audio line-in - rear
FCC Class A certified, UL, TUV, cUL, CB, KCC, KC
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
AC 120/230 V ( 50/60 Hz )
Smart energy saving
Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
Dimensions & Weight Details
Panel without stand - 73.1 cm 5.6 kg , Panel with stand - 73.1 cm x 20.7 cm x 48 cm x 5.8 kg , Panel with stand and speakers - 73.1 cm x 20.7 cm x 48 cm x 6.7 kg
Width (Shipping)
81.2 cm
Depth (Shipping)
13.9 cm
Height (Shipping)
50.5 cm
Weight (Shipping)
7.1 kg
10 - 80%
Accessories
£7.20
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£20.25
£38.41
£52.03
Scroll to top
