BT.com
Wishlist
LG Electronics 32LN5400 32" Full HD LED TV Full HD 1920 x 1080
Delivery
Standard Due date unavailable
Incredible Clarity, Vibrant Colours
FULL HD 1080p provides the pinnacle of picture resolution with incredible clarity and vibrant colours. With up to five times the resolution compared to standard definition TVs and twice that of `HD-Ready' TVs, FULL HD 1080p is the only way to enjoy the full potential of Blu-ray and HD gaming.
HDMI
High-Definition Multimedia Interface (HDMI) carries both sound and picture in a single cable from your devices to your high definition TV. Now you can easily connect your games console, satellite box, Blu-ray or Home Cinema System through the HDMI ports for a true high definition entertainment experience
Freeview
Get ready for the digital switch-over.
All LG TVs come with built-in Digital Freeview making sure you're ready for the digital switch-over. With LG TVs you'll have access to over 40 Freeview TV and radio channels, 8 day on-screen guide and access to digital interactive services.
*UK Only
LG 32LN5400 32" LED TV
LED-backlit LCD TV
Energy Class
Class A+
Diagonal Class
32"
73.8 cm x 7.9 cm x 43.7 cm
6 kg
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Motion Enhancement Technology
100 Hz Motion Clarity Index
24p Technology
24p Real Cinema
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
1 ports
HDCP Compatible
IPS
LCD Backlight Technology
LED backlight
Digital TV Tuner
DVB-C, DVB-S, DVB-T
USB Port
Yes , 1 ports
Remote Control
Standard remote
LED-backlit LCD TV
Energy Class
Class A+
Diagonal Class
32"
Video Interface
HDMI Ports Qty
1 ports
HDCP Compatible
Dimensions
Without stand
73.8 cm
7.9 cm
43.7 cm
6 kg
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p (Full HD)
24p Technology
24p Real Cinema
LED backlight
Widescreen Modes
Zoom 14:9, Conventional 4:3, Zoom, 16:9, Full Wide, Just Scan, Original, Cinema Zoom
Triple XD Engine
Stands & Mounts
Flat Panel Mount Interface
200 x 100 mm
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
DVB-C, DVB-S, DVB-T
Video Features
Teletext
Teletext Memory
2000 pages
Parental Channel Lock
Media Player
Supported Video Formats
DivX HD
Supported Pictures Formats
JPG, MPO
USB Port
Yes , 1 ports
Remote Control
Standard remote
Network & Internet Multimedia
Connect & Share
Mobile High-Definition Link (MHL)
Connector Type
Audio line-in - rear , HDMI - rear , USB 2.0 - side , Composite video / component video / audio input - rear , SCART - rear , Digital audio output (optical) - rear
Power supply
Dimensions & Weight Details
Panel without stand - 73.8 cm x 7.9 cm x 43.7 cm x 6 kg , Panel with stand - 73.8 cm x 20.7 cm x 49.7 cm x 6.7 kg
Scroll to top
