BT.com
Wishlist
LG Electronics 28LF491U Smart 28" FHD LED TV
LG Electronics 28LF491U Smart 28"...
£235.53
More than 50 in stock
£235.53
Add to wishlist
Delivery
Standard 1-3 working days
Smart platform brings together all of your favorite content. You can also stream live, there's also access to music.
Switch easily between 8 different picture modes so you can enjoy whatever you are watching with a recommended balance of color, contrast and sharpness.
By maximizing color reproduction, you can enjoy true-to-life colors the way they were meant to be seen.
LG 28LF491U 28" LED TV
LED-backlit LCD TV - Smart TV
Diagonal Class
28"
Resolution
1366 x 768
Display Format
720p
Motion Enhancement Technology
300 Picture Quality Index
24p Technology
24p True Cinema
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
2 ports
Wi-Fi, LAN
HDCP Compatible
IPS
LCD Backlight Technology
LED backlight
Digital TV Tuner
DVB-C, DVB-S2, DVB-T2
Internet Streaming Services
LG Cloud
Picture Enhancements
Colour Accuracy
Speaker System
2 speakers
Sound Effects
SMART SOUND, Virtual Surround Plus
USB
Remote Control
Standard remote
Energy Class
Class A+
Power Consumption (On mode)
25 W
Energy Consumption per Year
37 kWh
63.8 cm x 5.7 cm x 38.9 cm
4.3 kg
Energy Class
Class A+
25 W
37 kWh
Diagonal Class
28"
Extended PVR
Video Interface
HDMI Ports Qty
2 ports
HDCP Compatible
Colour Accuracy
Dimensions
Without stand
63.8 cm
5.7 cm
38.9 cm
4.3 kg
Display
LCD Display Technology
IPS
Resolution
1366 x 768
Display Format
720p
24p Technology
24p True Cinema
LED backlight
Triple XD Engine, Dual-Core processor, Dynamic Color Enhancer, Picture Wizard III
Stands & Mounts
Flat Panel Mount Interface
100 x 100 mm
Digital TV Tuner
Digital TV Tuner
Video Features
Teletext
Media Player
Supported Video Formats
DivX HD
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Surround Mode
Sound Effects
Audio Controls
Sound mode
Speaker System
2 speakers
Output Power / Total
10 Watt
Built-in Dolby Digital decoder, Clear Voice II technology, Sound Optimizer, Optical Sound Sync, Wireless Sound Sync
Speakers
2 x speaker - built-in - 5 Watt
Network & Internet Multimedia
Functionality
Digital audio playback, digital photo playback, digital video playback, Internet video playback
Wi-Fi, LAN
Connect & Share
Intel Wireless Display (WiDi), Wi-Fi Miracast, Smart Share
LG Cloud
Supported Consumer Electronics Control (CEC)
Simplink
DLNA
Connector Type
Composite video input , 2 x audio line-in , Component video input , 2 x HDMI , USB 2.0 , SCART , Digital audio output (optical) , Network , Headphones
Dimensions & Weight Details
Panel without stand - 63.8 cm x 5.7 cm x 38.9 cm x 4.3 kg , Panel with stand - 63.8 cm x 16 cm x 42.2 cm x 4.4 kg
Accessories
£235.53
Essential TV Accessory
£260.52
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Item condition Customer return - item has been used and shows signs of use
Ref: BJKT 035345
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£150.18
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
