Click to visit BT.com
BT.com
Wishlist
LG Electronics 26LN450B 26 Inch LED TV
Quicklinx: 8NDXWS00
Mfr#: 26LN450B
Essential accessories
High definition or HDTV offers greatly improved picture quality and sound than standard definition broadcasts. Finer detail, more colours and more vibrant images make High Definition the only choice when upgrading your TV.
Freeview - Get ready for the digital switch-over.
All LG TVs come with built-in Digital Freeview making sure you're ready for the digital switch-over. With LG TVs you'll have access to over 40 Freeview TV and radio channels, 8 day on-screen guide and access to digital interactive services.
*UK Only
Intelligent Sensor
ECO-FRIENDLY REVOLUTION - LG Intelligent Sensor technology automatically finds the optimal brightness, sharpness, colour and contrast picture settings to enhance the picture quality and reduce power consumption.
LG 26LN450B 26" LED TV
LED-backlit LCD TV
Energy Class
Class B
38 Watt
Diagonal Class
26"
62.1 cm x 7.29 cm x 38.6 cm - without stand
4.2 kg
Resolution
1366 x 768
Display Format
720p
Input Video Formats
720p, 1080i, 1080p
Motion Enhancement Technology
100 Hz Motion Clarity Index
24p Technology
24p Real Cinema
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
1 ports
HDCP Compatible
LCD Backlight Technology
LED backlight
Intelligent Sensor, Eye Care, Picture Wizard II, Enhanced Noise Reduction, Triple XD Engine, Mobile High-Definition Link (MHL)
Speaker System
2 speakers
Sound Effects
Virtual Surround Mode
Stereo Reception System
MTS
USB Port
Yes , 1 ports
Remote Control
Remote control
AC 120/230 V ( 50/60 Hz )
LED-backlit LCD TV
Energy Class
Class B
38 Watt
Diagonal Class
26"
Video Interface
HDMI Ports Qty
1 ports
HDCP Compatible
Dimensions
Without stand
62.1 cm
7.29 cm
38.6 cm
4.2 kg
Display
Resolution
1366 x 768
Display Format
720p
24p Technology
24p Real Cinema
LED backlight
Widescreen Modes
Conventional 4:3, Zoom, 16:9, Full Wide, Just Scan, Original, Cinema Zoom
Stands & Mounts
Flat Panel Mount Interface
100 x 100 mm
TV Tuner
Conditional Access
Common Interface (CI) slot
MTS
Secondary Audio Programme (SAP)
Video Features
Input Video Formats
720p, 1080i, 1080p
Electronic Programme Guide
Digital EPG
Parental Channel Lock
Media Player
Supported Video Formats
DivX HD
Supported Audio Formats
MP3, PCM, AC3, AAC, E-AC3
Supported Pictures Formats
JPG
USB Port
Yes , 1 ports
Remote Control
Remote control
Audio System
Digital Audio Format
Dolby Digital output
Surround Mode
Sound Effects
Audio Controls
Sound mode
Speaker System
2 speakers
Output Power / Total
10 Watt
Clear Voice II technology
Speakers
2 x speaker - built-in - 5 Watt
Connector Type
1 x audio line-in - side , 1 x HDMI ( 19 pin HDMI Type A ) - rear , 1 x USB 2.0 ( 4 PIN USB Type A ) - side , 1 x component video input ( RCA x 3 ) - rear , 1 x SCART ( 21 PIN SCART ) - rear , 1 x composite video/audio input ( RCA x 2 ) - rear , 2 x audio input - rear , 1 x headphones ( mini-phone stereo 3.5 mm ) - side
Power supply
Nominal Voltage
Dimensions & Weight Details
Panel without stand - 62.1 cm x 7.29 cm x 38.6 cm x 4.2 kg , Panel with stand - 62.1 cm x 16.21 cm x 43.1 cm x 4.5 kg
