BT.com
Wishlist
LG Electronics 24MP57VQ 24" 1920 x 1080 5ms LED IPS VGA HDMI Tilt
Delivery
Standard Due date unavailable
The LG IPS monitor ensures an awesome picture quality that provides clear images and vivid colors from any angle. LG's IPS Monitor provides accurate color for your viewing pleasure.
The 4-Screen Split feature improves productivity by simply re-sizing the windows on your screen. With one drag you can re-size one window and the other windows automatically to fir the available space. It allows from 2 to 4 windows to be shown in 8 different screen ratios without feeling cluttered.
It's easy to build up a multi-tasking environment with multiple monitors. Color Cloning APP helps you to match the color quality and brightness between two LG monitors that are connected to the same PC.
LG 24MP57VQ - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
37 kWh
Power Consumption (On mode)
25 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Screen Coating
Anti-glare, 3H Hard Coating
55.5 cm x 19.5 cm x 43.6 cm
Plug and Play
Display Type
Energy Class
Class B
37 kWh
25 W
Diagonal Size
24"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
SUPER + Resolution, Mega Contrast Ratio, 4-screen split, Flicker Safe, Reader Mode, Color Cloning, Smart Energy Saving technology, Color Wizard
55.5 cm x 19.5 cm x 43.6 cm - with stand
HDMI , DVI-D (HDCP) , VGA , Headphones
Plug and Play
Power Supply
Internal
26 Watt
Power Consumption Stand by
0.3 Watt
Dimensions & Weight Details
With stand - width: 55.5 cm - depth: 19.5 cm - height: 43.6 cm , Without stand - width: 55.5 cm - depth: 6.5 cm - height: 33.9 cm
Scroll to top
