BT.com
Wishlist
LG Electronics 23EA63V 23" LED IPS 1920x1080 VGA DVI HDMI
Delivery
Standard Due date unavailable
Marketing description is not available.
LG 23EA63V - LED monitor - 23"
LED-backlit LCD monitor - 23"
Panel Type
AH-IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2652 mm
Brightness
250 cd/m²
Contrast Ratio
10000000:1 (dynamic)
Response Time
14 ms (typical); 5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
53 cm x 18 cm x 39.5 cm
3 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
FCC Class B certified, UL, cUL, DDC/CI, TCO Displays 5.2
Display Type
Diagonal Size
23"
Panel Type
AH-IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.2652 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
HDCP, Picture Mode, SUPER Energy Saving Technology, CINEMA Screen Design
53 cm x 18 cm x 39.5 cm - with stand
3 kg
HDMI , DVI-D , VGA
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
75 x 75 mm
1 x VGA cable
29 Watt
Power Consumption Stand by / Sleep
0.3 Watt
Dimensions & Weight Details
With stand - width: 53 cm - depth: 18 cm - height: 39.5 cm - weight: 3 kg , Without stand - width: 53 cm - depth: 7 cm - height: 31.8 cm - weight: 2.8 kg
EPEAT Compliant
EPEAT Gold
Accessories
£7.23
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£20.25
£39.28
£52.56
Scroll to top
