BT.com
Wishlist
LG Electronics 22MP67VQ 22" 1920x1080 5ms VGA DVI-D HDMI IPS LED Monitor
Delivery
Standard Due date unavailable
With an LG computer monitor you'll discover cutting-edge display technology and slim designs, from the LG CINEMA 3D monitor, the standard in 3-dimensional excellence, to the dazzling LED and LCD monitors, which offer state-of-the-art display and features. You'll get a outlook on life with monitors and other computer equipment from LG.
LG 22MP67VQ - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class B
Energy Consumption per Year
35 kWh
Power Consumption (On mode)
24 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.24795 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
50 cm x 20.5 cm x 40.7 cm
3 kg
Plug and Play, FCC Class B certified, UL, TUV, cUL, DDC/CI, Directive 2004/108/EC, Directive 2006/95/EC, EN 61000-3-3:2008, Directive 2009/125/EC, EN 61000-3-2:2006+A1:2009+A2:2009, EPA 6.0, EN 50564:2011, EN 50581:2012, EN 60950-1:2006+A11:2009+A1:2010+A12:2011, RoHS 2011/65/EU, EN 50563:2011, EN 55024:2010, EN 55022:2010, IEC 62087:2008
Display Type
Energy Class
Class B
35 kWh
24 W
Diagonal Size
21.5"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24795 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
HDCP, 72% colour gamut, SUPER + Resolution, CINEMA Screen Design, 4-screen split, Flicker Safe, Reader Mode, Joystick, Color Cloning, Smart Energy Saving technology, Color Wizard, Color Calibration
50 cm x 20.5 cm x 40.7 cm - with stand
3 kg
HDMI , Headphones , VGA , DVI-D
Mechanical
Tilt
Tilt Angle
-3/+20
Flat Panel Mount Interface
75 x 75 mm
1 x VGA cable
Power Supply
External
21 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Windows 8
Dimensions & Weight Details
With stand - width: 50 cm - depth: 20.5 cm - height: 40.7 cm - weight: 3 kg , Without stand - width: 50 cm - depth: 5.2 cm - height: 30.6 cm - weight: 2.6 kg
Scroll to top
