BT.com
Wishlist
LG Electronics 22MB65PM-B 22" 1680x1050 5ms VGA DVI LED IPS Monitor
Delivery
Standard Due date unavailable
Display
LG LED Monitor features HD resolution(1680*1050), resulting in 250nit of its brightness which brings a crystal-clear image. Fast response time of 5ms helps you to avoid motion blur and let you enjoy the fastest action movies as well.
Stereo Speakers
Built in stereo speaker enables you to take a sound test without extra speakers.
Energy Saving
Enjoy the bright screen without any image loss. Save additional energy compared to conventional LED monitors. * Conserve energy by adjusting screen brightness.
Reader Mode
Reducing blue light to protect your eyes, Reader Mode provides optimal condition for reading. With just a touch of a button, you can comfortably read on the monitor for long.
Flicker Safe
Protect your eyes from exhausting flickers and blue lights. LG's new Flicker Safe system is always on to reduce the flicker level to almost-zero. In addition, activate the Reader Mode to minimize harmful blue lights with a simple touch of a hot-key. Spend as long as you want working, gaming, or watching movies without burdening your eyes. Use the convenient and easy hot keys for more satisfaction.
Ergonomic Design
Our swivel tilting monitor has diverse swivel & tilt options ranged from 15° to 68° and from -5° to 20° respectively, to be perfectly adjusted for varied eye level and working conditions. Also, our pivot monitor can be changed to vertical anytime you want, keeping up with business situations like dealing with vertically long contents.
Built-in Power
Experience built-in adaptor which used to be assembled in the power cable. Feel how our built-in adaptor remarkably changed installation time to be a more convenient by omitting any struggles to pull it out from small size cable hole.
LG 22MB65PM-B - LED monitor - 22"
LED-backlit LCD monitor - 22"
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
1680 x 1050 at 60 Hz
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Anthracite dark
50.6 cm x 5.8 cm x 33.9 cm
3.5 kg
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, CSA, UL, TUV GS, C-Tick, NEMKO, SEMKO, VCCI-II, EN 61000-3-3, EN55024, EN55022 Class B, TUV Ergo, ISO 9241-307, EN 61000-3-2:2006, TCO Displays 6.0, EN 60950-1:2006
3 years warranty
Display Type
Diagonal Size
22"
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
135 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
WLED
Controls & Adjustments
Contrast, H/V position, gamma correction, phase, clock
Power off timer, Digital Fine Contrast (DFC), 4:3 in Wide, SUPER Energy Saving Technology, Multiscan Support
Anthracite dark
50.6 cm x 5.8 cm x 33.9 cm - without stand
3.5 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
VGA , DVI-D (HDCP) , Audio line-in , Audio line-out
Mechanical
Tilt Angle
-5/+20
Swivel Angle
355
Rotation Angle
90
Height Adjustment
120 mm
Flat Panel Mount Interface
100 x 100 mm
Backlight Life
50,000 hours
Power Supply
Internal
21 Watt
Power Consumption Stand by
0.3 Watt
Dimensions & Weight Details
With stand - width: 50.6 cm - depth: 23.9 cm - height: 37.9 cm - weight: 4.7 kg , Without stand - width: 50.6 cm - depth: 5.8 cm - height: 33.9 cm - weight: 3.5 kg
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - backlight - 3 years
Accessories
£7.96
£8.85
£12.16
C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL
Quicklinx: 63SL | In Stock
£9.90
£6.00
C2G USB to DVI Adapter Up To 2048 x 1152
Quicklinx: 8H1Y | In Stock
£41.59
C2G 2m HDMI to DVI-D Digital Video Cable
Quicklinx: 915T | In Stock
£8.38
£56.05
Scroll to top
