BT.com
Wishlist
LG Electronics 22EA53VQ 21.5" 1920x1080 5MS VGA DVI HDMI IPS LED Monitor
Delivery
Standard Due date unavailable
Marketing description is not available.
LG 22EA53VQ - LED monitor - 21.5"
LED-backlit LCD monitor - 21.5"
Panel Type
AH-IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
1920 x 1080
Pixel Pitch
0.24795 mm
Brightness
250 cd/m²
Contrast Ratio
5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
50.8 cm x 18.1 cm x 38.5 cm - with stand
2.8 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
FCC Class B certified, UL, TUV GS, cUL, DDC/CI, TCO Displays 6.0
Display Type
Diagonal Size
21.5"
Panel Type
AH-IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
1920 x 1080
Pixel Pitch
0.24795 mm
Brightness
250 cd/m²
Contrast Ratio
5000000:1 (dynamic)
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
HDCP, SUPER Energy Saving Technology
2.8 kg
HDMI , DVI-D , VGA , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
75 x 75 mm
1 x VGA cable
25 Watt
Power Consumption Stand by / Sleep
0.3 Watt
Dimensions & Weight Details
With stand - width: 50.8 cm - depth: 18.1 cm - height: 38.5 cm - weight: 2.8 kg , Without stand - width: 50.8 cm - depth: 5.5 cm - height: 31.2 cm - weight: 2.58 kg
EPEAT Compliant
EPEAT Gold
Scroll to top
