BT.com
Wishlist
LG Electronics 22" 1920 x 1080 VGA DVI-D Black Full HD LED Monitor
LG Electronics 22" 1920 x 1080 VGA...
£136.05
11 in stock
£136.05
Add to wishlist
Delivery
Standard 1-3 working days
An immersive work environment is ensured through realistic color expression thanks to sRGB over 99 percent and the IPS display.
The coexistence of smoothness and solidness in the curved structure. The beauty of ArcLine is the icing on the cake.
Flicker safe and reader mode help maximize visual comfort by protecting your eyes from harmful blue light and reducing the flicker level to almost zero.
LG 22MP68VQ - LED monitor - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class A
Energy Consumption per Year
24 kWh
Power Consumption (On mode)
16 W
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.25 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
49.12 cm x 18.68 cm x 38.77 cm
2.8 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, UL, TUV, cUL, DDC/CI, ERP
Display Type
Energy Class
Class A
24 kWh
16 W
Diagonal Size
22"
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.25 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Power off timer, HDCP, SUPER Energy Saving Technology, SUPER + Resolution, game mode, Cinema Mode, On-screen Digital Controls, Flicker Free technology, 4-screen split, Reader Mode, 6-axis colour adjustment, Color Wizard, Black Stabilizer, Response Time Control, FreeSync Technology, Intelligent Auto, Color Weakness Mode, Mega DFC, Original ratio
49.12 cm x 18.68 cm x 38.77 cm - with stand
2.8 kg
HDMI , DVI-D , VGA , Headphones
Mechanical
Tilt
Tilt Angle
-2/+15
Flat Panel Mount Interface
75 x 75 mm
Key lock
1 x VGA cable
AC 120/230 V
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 49.12 cm - depth: 18.68 cm - height: 38.77 cm - weight: 2.8 kg , Without stand - width: 49.12 cm - depth: 9.17 cm - height: 29.33 cm - weight: 2.4 kg
Scroll to top
