BT.com
Wishlist
LG 43UD79-B 43" 3840x2160 5ms HDMI DisplayPort IPS LED Monitor
LG 43UD79-B 43" 3840x2160 5ms HDMI...
£683.76
Hurry, only 2 left in stock!
£683.76
Add to wishlist
Delivery
Standard 1-3 working days
The 43UD79-B, this 42.5-inch display has a native UHD resolution of 3840 x 2160 with a conventional refresh rate of 60Hz. It features an IPS panel with a non-glare coating, a peak brightness of 350 cd/m2, a contrast ratio of up to 1000:1, and an 8ms gray-to-gray (GTG) response time. The viewing angles are wide at 178°/178°, which is typical for an IPS display. Although support for 1.07 billion colors is claimed, the lack of an explicit mention of a 10-bit panel leads us to believe that this is an 8-bit panel using A-FRC to achieve a 10-bit color depth. On the plus side, this model will ship color calibrated from the factory.
LG 43UD79-B - LCD monitor - 4K - 42.51"
LCD monitor - 42.51"
USB 3.0 hub
Panel Type
IPS
Native Resolution
4K 3840 x 2160
Pixel Pitch
0.2451 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
8 ms (grey-to-grey)
Colour Support
1.06 billion colours
Input Connectors
4xHDMI, DisplayPort
3 years warranty
Display Type
LCD monitor / TFT active matrix
Diagonal Size
42.51"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Native Resolution
4K 3840 x 2160
Pixel Pitch
0.2451 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
8 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Mega DFC
4 x HDMI , DisplayPort , USB-C , 2 x USB 3.0 downstream , Serial , Audio line-out
Limited warranty - 3 years
Scroll to top
