BT.com
Wishlist
LG 27UD69P 27" 3840x2160 5ms HDMI DisplayPort AH-IPS LED Monitor
Delivery
Standard 1-3 working days
Heart-Pumping Gaming Experience on UHD 4K
Playing RPG or FPS games in UHD 4K provides you a lifelike gaming experience through its as highly detailed weapons and wonderful textures. The actions in racing games will be much vibrant on LG IPS display as it does away with colour distortion from any angle. Enjoy the best 4K games with thrilling graphics as they are rendered.
3 Side Borderless Design & Slim ArcLine Stand
Extremely thin bezel on three sides of the display offers a borderless visual experience. Slim ArcLine designed stand lets you experience the state-of-the-art viewing in various settings.
Tear-Free Gaming with AMD FreeSync Technology
With FreeSync, you can play graphics-intensive games without screen tearing and stuttering which can occur during rendering. Also, there are additional versatile gaming feature options for a better gaming experience.
Make Real-Time Commands and Attack First
The Dynamic Action Sync mode allows users to instantly attack the opponent without delay. It synchronizes your senses with real-time scenes happening in a fast-paced game by minimizing input lag.
Full Visibility even in the Darkest Corners
While playing shooting games, the Black Stabilizer gives gamers full visibility even in deep-dark scenes. It automatically senses the darkest side and makes it brighter so that you can find the enemies hiding and waiting to attack you in the dark.
Easy User Interface with On-screen Control 2.0
Every step of installing and controlling is easy without any hassle. On-screen Control S/W (2.0) allows you adjust customize all the display options with a few clicks including pivot control.
Multiple Screen Split Options
Through On-screen Control Software, select most needed screen setting among 14 of Screen Split options and optimize Multi-tasking Windows organization and screen real estate use.
Easy Control of Pivoted Ergonomic Stand
Maximize work efficiency of graphic works on vertical frames such as web editing and blogging. Simply rotate the screen as needed and view the display without scrolling. The height adjustment feature adds convenience. On-screen Control S/W allows you to adjust and customize all the display options with a few clicks including pivot control.
What's in the box
  • LG 27UD69P-W
  • HDMI cable
  • DisplayPort cable
LG 27UD69P-W - LED monitor - 4K - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
44 kWh
Power Consumption (On mode)
30 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 60 Hz)
Pixel Pitch
0.157 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
1.073 billion colours (8-bit)
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Height, pivot (rotation), tilt
Screen Coating
Anti-glare, 3H Hard Coating
White, silver
61.5 cm x 18.62 cm x 45.57 cm
4.9 kg
FCC Class B certified, cUL, CB, DDC/CI, RoHS, REACH, KC, ERP, EPA 7.0, HDCP 2.2
2 years warranty
Display Type
Energy Class
Class A
44 kWh
30 W
Diagonal Size
27"
Viewable Size
27"
AMD FreeSync
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.157 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 61 Hz
Horizontal Refresh Rate
30 - 135 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
Split screen, SUPER + Resolution, Mega Contrast, Black eQualizer, On-screen Digital Controls, 4-screen split, Flicker Safe, Reader Mode, SIX Axis Control, Factory Calibration, Dual Controller, DAS Mode (Dynamic Action Sync), Color Weakness Mode, 99% sRGB (CIE 1931) colour gamut, borderless
White, silver
61.5 cm x 18.62 cm x 45.57 cm - with stand
4.9 kg
2 x HDMI , DisplayPort , Audio line-out
Mechanical
Tilt Angle
-2/+15
Flat Panel Mount Interface
100 x 100 mm
1 x HDMI cable , 1 x DisplayPort cable
40 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 61.5 cm - depth: 18.62 cm - height: 45.57 cm - weight: 4.9 kg , Without stand - width: 61.5 cm - depth: 4.93 cm - height: 36.51 cm - weight: 4.6 kg
Limited warranty - parts and labour - 2 years
Scroll to top
