BT.com
Wishlist
Lexmark Booklet Finisher 4-Hole Paper Handling Option
Lexmark Booklet Finisher 4-Hole...
£3,977.56
£3,977.56
Add to wishlist
Delivery
Standard Due date unavailable
The upper bin supports up to 500 sheets of paper in A3, A4, A5, folio, executive, JIS-B4, JIS-B5, letter, legal, ledger or tabloid and statement sizes. Bin 1, the middle bin, supports up to 1500 sheets of paper in A3, A4, executive, folio, JIS-B4, JIS-B5, letter, legal and ledger or tabloid sizes. Stapling of sets of 50 sheets of paper is supported. Hole punching of paper (16 to 47 lb., 60 to 176 gsm) and offset stacking is supported. Bin 1 has an empty and a full sensor.
Bin 2, the lower bin, supports paper in A3, A4, executive, folio, JIS-B4, JIS-B5, letter, legal and ledger or tabloid sizes (16 to 24 lb., 60 to 90 gsm). The lower bin supports saddle stapling of up to 18 sets with up to 15 sheets of folded 20 lb. paper. Bin 2 has a full sensor.
Lexmark finisher with stacker/stapler/booklet folder - 2000 sheets
Finisher with stacker/stapler/booklet folder
Punching Type
4-hole
Total Media Capacity
2000 sheets in 3 trays
75 cm x 68 cm x 99.8 cm
43.6 kg
Media Type
Plain paper
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), Statement (139.7 x 215.9 mm)
Lexmark XS950de, XS955de, XS955dhe; C950DE, 950dte; X950DE, 950dhe, 950dte, 952DE, 952DTE, 954DE, 954DHE
Punching Type
4-hole
Media Type
Plain paper
Media Sizes
75 cm - 68 cm - 99.8 cm
43.6 kg
Lexmark XS950de, XS955de, XS955dhe , Lexmark C950DE, 950dte , Lexmark X950DE, 950dhe, 950dte, 952DE, 952DTE, 954DE, 954DHE
Scroll to top
