BT.com
Wishlist
Lexmark 550 Sheet Tray - MS81x MX71x
Lexmark 550 Sheet Tray - MS81x...
£244.63
45 in stock
£244.63
Add to wishlist
Delivery
Standard 1-3 working days
This unit supports A4, A5, A6, Executive, Folio, JIS B5, Letter, Legal, Oficio and Statement sizes. Paper (16 to 47 lb., 60 to 176 gsm), transparencies, card stock, and labels may be used from this tray. Envelopes in sizes 7¾, 9, 10, B5, C5 and DL may also be used from this tray. Paper size, paper and tray-present and tray-low and tray-empty sensing are supported. The optional caster base may be required when the product is configured with the spacer or additional trays (1 to 4).
Lexmark media tray - 550 sheets
Media tray
Total Media Capacity
550 sheets in 1 trays
42.2 cm x 51.1 cm x 10.9 cm
5.81 kg
Media Type
Envelopes, transparencies, labels, plain paper, cards
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), Oficio (216 x 343 mm)
Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.4 x 225.4 mm)
Lexmark M5155, M5163, M5170, MS810de, MS810dn, MS810dtn, MS810n, MS811dn, MS811dtn, MS811n, MS812de, MS812dn, MS812dtn, MX710de, MX710dhe, MX711de, MX711dhe, MX711dthe, XM5163, XM5170
Media tray
Media Type
Media Sizes
Envelope Sizes
42.2 cm - 51.1 cm - 10.9 cm
5.81 kg
Scroll to top
