BT.com
Wishlist
Lexar JumpDrive Triton - USB flash drive - 16 GB - USB 3.0
Delivery
Standard Due date unavailable
Premium, SuperSpeed USB 3.0 Flash Drive
One of the fastest USB flash drives available, the ultra-portable Lexar® JumpDrive® Triton USB 3.0 flash drive leverages SuperSpeed USB 3.0 technology to deliver blazing-fast transfer speeds, with write speeds up to 150MB/s.* The drive is ultra portable for everyday use and boasts a sleek metal alloy design. Lexar JumpDrive Triton is available in 16GB, 32GB and 64GB capacities.
Sleek, High-Performance Portable Storage
Among the Fastest USB Flash Drives Available. The Lexar Triton USB 3.0 flash drive leverages SuperSpeed USB 3.0 technology to provide blazing-fast file transfer, with up to 155MB/s read and 150MB/s write (more than 20x faster than standard drives). This gives you the power, for example, to quickly and easily transfer 100 songs in less than 20 seconds and a full-length HD movie in less than 40 seconds.
Sleek Metal Alloy Design. Beyond its powerful capabilities, the drive has a sleek design with a metal alloy base and high-gloss mirror finish top that you'll want to show off wherever you go. What's more, its retractable connector with convenient thumb slide makes it so easy to use, you can do it with one hand. With its premium look and feel, JumpDrive Triton is an excellent solution for those looking for a durable and well-designed USB 3.0 flash drive.
Ultra Portable Size for Everyday Use. The ultra-portable JumpDrive Triton is sized for convenience. This easily-accessible portable storage solution provides both high-speed performance and high-capacity options, so you can quickly store and transfer large libraries of multimedia content and a vast number of files. And with its convenient size, it fits nicely in your pocket for life on the go.
Lexar Performance, Quality, Compatibility, and Reliability. All Lexar memory card, card reader, and USB flash drive product designs undergo extensive testing in the Lexar Quality Labs, facilities with more than 800 digital devices, to ensure performance, quality, compatibility, and reliability. This provides customers with a high level of confidence when using Lexar products to capture, manage, move, and store the memories that matter.
USB flash drive
Interface Type
USB 3.0
Storage Capacity
16 GB
USB flash drive
Storage Capacity
16 GB
Compatibility
Non-specific
Read Rate
Up to 155 MB/s
Write Rate
Up to 150 MB/s
Interface Type
USB 3.0
Retractable connector
Limited warranty - lifetime
Scroll to top
