BT.com
Wishlist
Lenovo ThinkVision X24 23.8" 1920x1080 7ms HDMI DP LED Monitor
Delivery
Standard Due date unavailable
Innovative and elegant with infinity screen and 7.5 mm ultra-slim profile, ThinkVision X24 would be the centrepiece of any desk space. Featuring the next-generation Neo-Blade 23.8-inch panel, the X24 utilises the unique pre-coated metal surface technology in place of a traditional rear cover, enhancing the premium design. Offering not just form over function, the X24 also features an AH-IPS panel with Full HD resolution, making the images vivid and of good quality even at a 178-degree viewing angle. Connectivity options are all digital with DisplayPort and HDMI. It also has a stylish and sturdy chrome stand that is tilt-adjustable for ergonomic viewing.
Lenovo ThinkVision X24 - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
7 ms
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Tilt
Raven black
54.09 cm x 22 cm x 41.28 cm
3.9 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, RoHS, ISO 9241-307, WEEE, TCO Displays 6.0
Display Type
Diagonal Size
23.8"
Viewable Size
23.8"
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
94
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
7 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
HDCP, 72% colour gamut
Raven black
3.9 kg
HDMI , DisplayPort
Mechanical
Tilt
Tilt Angle
-5/+22
Stand
1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
24 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Microsoft Windows 7 / 8 / 8.1
ENERGY STAR Certified
45 °C
8 - 80%
Accessories
£9.99
£7.15
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£19.86
£38.52
£52.15
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£59.19
Scroll to top
