BT.com
Wishlist
Lenovo ThinkVision Tiny-in-One 23" 1920x1080 5ms VGA DVI DisplayPort LED Monitor
Delivery
Standard Due date unavailable
Maximise desktop versatility and keep TCO in check. This compact Tiny-in-One (TIO) delivers a full All-in-One experience with simple setup, clutter-free cabling and extensive configurability options including a broad selection of Tiny products and accessories – all in a Tiny form factor. It's unique because it's an AIO, yet the CPU and monitor are separate modules so they can be maintained and upgraded individually – there's no need to replace or repair the entire system. Perfect for large organisations and any space-constrained environment.
Lenovo ThinkCentre Tiny-in-One 23 - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DisplayPort
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare
56.3 cm x 25 cm x 52.014 cm
7 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, CSA, TUV, TUV GS, VCCI, C-Tick, BSMI, cUL, VESA DPMS, VESA FPMPMI, CCC, IC, RoHS, ISO 9241-307, WEEE, JEITA, KC, CECP, DDC-2B/CI, TCO Certified Edge 1.1
3 years warranty
Display Type
Diagonal Size
23"
Viewable Size
23"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Pixel Per Inch
96
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
WLED
72% colour gamut
56.3 cm x 25 cm x 52.014 cm - with stand
7 kg
DisplayPort , Headphone/microphone combo jack
Mechanical
Tilt Angle
35
Swivel Angle
45
Height Adjustment
110 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), 88% efficiency power supply
Mounting Kit
Optional
Power Supply
External
22 Watt
Power Consumption Stand by
0.5 Watt
Microsoft Windows 7, Microsoft Windows Vista, Windows 8, Windows 8.1
ENERGY STAR Certified
International warranty - replacement - 3 years
8 - 80%
Accessories
C2G HDMI to DisplayPort Adapter Converter
Quicklinx: 9MR6 | In Stock
£40.22
£24.72
£9.80
£20.37
£18.12
£13.87
Scroll to top
