BT.com
Wishlist
Lenovo ThinkVision T2454p 24" 1920x1200 7ms VGA GDMI LED Monitor
Delivery
Standard Due date unavailable
Ideal for professional use, ThinkVision T2454p LCD monitor offers high resolution and in plane switching panel which can maximize your viewing angle and visual experience. It also has multiple interface options and integrated USB 3.0 hub that makes your connectivity easier. Boasting low energy consumption and less environmental impact, T2454p meets green standards.
Lenovo ThinkVision T2454p - LED monitor - 24"
LED-backlit LCD monitor - 24"
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
7 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Raven black
55.74 cm x 26.42 cm x 40.25 cm
6.15 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, TUV, RoHS, ISO 9241-307, WEEE, Green Mark, TCO Certified Edge, DDC-2B/CI, TCO Displays 6.0, UL Environmental SPC Gold, CEL Grade 1, TCO Certified Edge 2.0
3 years warranty
Display Type
Diagonal Size
24"
Viewable Size
24"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
7 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
HDCP, 77.4% colour gamut
Raven black
55.74 cm x 26.42 cm x 40.25 cm - with stand
6.15 kg
VGA , DisplayPort , HDMI , 4 x USB 3.0 downstream , USB 3.0 upstream , Audio line-out
Mechanical
Tilt Angle
-5/+30
Swivel Angle
90
Rotation Angle
90
Height Adjustment
110 mm
Flat Panel Mount Interface
100 x 100 mm
1 x DisplayPort cable - 1.8 m , 1 x VGA cable - 1.8 m , 1 x SuperSpeed USB cable - 1.8 m
AC 100/240 V (50/60 Hz)
24 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Microsoft Windows 7, Windows 8, Windows 8.1
Dimensions & Weight Details
Without stand - width: 55.74 cm - depth: 4.4 cm - height: 36.3 cm - weight: 4.22 kg
ENERGY STAR Certified
Limited warranty - replacement - 3 years - carry-in
45 °C
10 - 80% (non-condensing)
Accessories
Accessories
£136.50
StarTech.com Articulating Monitor Arm
Quicklinx: BHCN | In Stock
£122.86
StarTech.com Dual Monitor Stand
Quicklinx: C19Z | In Stock
£83.71
StarTech.com Cubicle Monitor Hanger
Quicklinx: CFQK | In Stock
£54.63
StarTech.com TV/Monitor Arm - Wallmount
Quicklinx: CFR4 | In Stock
£78.81
Other bundles
Lenovo Microsaver Security Cable Lock
Quicklinx: 393T | In Stock
£41.38
Scroll to top
