BT.com
Wishlist
Lenovo ThinkVision T2424p 24" 1920x1080 7ms VGA DP HDMI LED Monitor
Delivery
Standard Due date unavailable
The ThinkVision T2424p LCD Monitor offers FHD resolution and a professional In-plane Switching panel to maximise the viewing angle and visual experience. It offers multiple interface options (VGA + HDMI + DP) and integrated USB3.0 hub, making it easy to connect. Boasting low energy consumption and less environmental impact, it meets the latest green standards: Energy Star 6.0, TUV Green Mark, EPEAT Gold, UL Environment Gold and more.
Lenovo ThinkVision T2424p - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 3000000:1 (dynamic)
Response Time
7 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Raven black
56.36 cm x 26.42 cm x 37.25 cm
5.85 kg
English / United Kingdom
FCC Class B certified, MPR II, CSA, UL, TUV GS, VCCI, C-Tick, BSMI, cUL, GS, NEMKO, NOM, SABS, SASO, TUV S, CCC, IC, PSB, RoHS, ISO 9241-307, KCC, WEEE, PSE Mark, JEITA, MEPS, E-Standby, TUV GM, KC, Kvalitet, KUCAS, SONCAP, KEBS, CECP, CEL, TCO Displays 6.0, UL Environmental SPC Gold, INSM, EAC, ISC, TCO Certified Edge 2.0
3 years warranty
Display Type
Diagonal Size
23.8"
Viewable Size
23.8"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
7 ms
Vertical Refresh Rate
60 - 75 Hz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, input select, colour temperature
OSD Languages
Chinese (simplified), English, German, French, Italian, Russian, Spanish, Japanese
Anti-glare, 72% colour gamut
Raven black
5.85 kg
VGA , HDMI , DisplayPort , 4 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
Tilt Angle
-5/+30
Swivel Angle
90
Rotation Angle
90
Height Adjustment
110 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management
1 x SuperSpeed USB cable - 1.8 m , 1 x VGA cable - 1.8 m
Power Supply
Internal
22 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Microsoft Windows Vista / 7 / 8 / 8.1
Dimensions & Weight Details
Without stand - width: 56.36 cm - depth: 4.4 cm - height: 33.3 cm - weight: 3.85 kg
Limited warranty - 3 years - carry-in
Accessories
£9.99
£6.91
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.84
£36.18
£49.00
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£55.62
£17.48
Scroll to top
