BT.com
Wishlist
Lenovo ThinkVision T2324p 23" 1920x1080 7ms VGA HDMI DisplayPort IPS LED Monitor
Delivery
Standard Due date unavailable
Enjoy uncompromising performance with the ThinkVision T2324p LCD Monitor. This monitor offers FHD resolution and a professional In-plane Switching panel to maximise your viewing angle and visual experience. The T2324p also provides multiple interface options (VGA + HDMI + DP) and integrated USB3.0 hub, making it easy to connect. Boasting low energy consumption and less environmental impact, the T2324p adopts the latest green standards, meeting Energy Star 6.0, TUV Green Mark, EPEAT Gold, UL Environment Gold and more.
Lenovo ThinkVision T2324p - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2652 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
7 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
54.58 cm x 26.41 cm x 50.9184 cm
5.4 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, MPR II, TUV GS, VCCI, C-Tick, BSMI, cUL, GS, IEC950, NEMKO, NOM, SABS, SASO, TUV S, CCC, PSB, Lead-Free, SII, ISO 9241-307, KCC, WEEE, PSE Mark, JEITA, cTUVus, MEPS, TUV GM, KC, Kvalitet, KUCAS, SONCAP, KEBS, CECP, CEL, TCO Displays 6.0, UL Environmental SPC Gold, INSM, EAC, CEL Grade 1, China RoHS, ISC
3 years warranty
Display Type
Diagonal Size
23"
Viewable Size
23"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2652 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
7 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
205 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Colour Temperature
9300K, 7200K, 6500K
Controls & Adjustments
Brightness, contrast, H/V position, input select, colour temperature
OSD Languages
Chinese (simplified), English, German, French, Italian, Russian, Spanish, Japanese
72% colour gamut
54.58 cm x 26.41 cm x 50.9184 cm - with stand
5.4 kg
HDMI , DisplayPort , VGA , 4 x USB 3.0 downstream , USB 3.0 upstream , Audio line-out
Mechanical
Tilt Angle
-5/+30
Swivel Angle
90
Rotation Angle
90
Height Adjustment
110 mm
Flat Panel Mount Interface
100 x 100 mm
Power Supply
Internal
AC 100/240 V / DC 12 V (50/60 Hz)
21 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Microsoft Windows 7, Windows 8, Windows 8.1
Dimensions & Weight Details
Without stand - height: 36.25 cm
ENERGY STAR Certified
Limited warranty - replacement - 3 years - carry-in
45 °C
10 - 80%
Accessories
£9.99
£6.91
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.84
£36.18
£49.00
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£55.62
£17.48
Scroll to top
