BT.com
Wishlist
Lenovo ThinkVision T2224p 21.5" 1920x1080 7ms VGA HDMI DisplayPort LED Monitor
Delivery
Standard Due date unavailable
Enjoy professional performance with the ThinkVision T2224p LCD Monitor. This monitor offers FHD resolution and a professional In-plane Switching panel to maximise your viewing angle and visual experience. The T2224p also provides multiple interface options and integrated USB3.0 hub, making it easy to connect. In addition, it adopts the latest green standards, meeting Energy Star 6.0, TUV Green Mark, EPEAT Gold and UL Environment Gold. On top of this, it boasts lower energy consumption and a lesser environmental impact.
Lenovo ThinkVision T2224p - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 3000000:1 (dynamic)
Response Time
7 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Raven black
51.29 cm x 24.27 cm x 34.43 cm
4.84 kg
English / United Kingdom
FCC Class B certified, MPR II, CSA, UL, TUV GS, VCCI, C-Tick, BSMI, cUL, GS, NEMKO, NOM, SABS, SASO, TUV S, CCC, IC, PSB, RoHS, ISO 9241-307, KCC, WEEE, PSE Mark, JEITA, MEPS, E-Standby, TUV GM, KC, Kvalitet, KUCAS, SONCAP, KEBS, CECP, CEL, TCO Displays 6.0, UL Environmental SPC Gold, INSM, EAC, ISC, TCO Certified Edge 2.0
3 years warranty
Display Type
Diagonal Size
21.5"
Viewable Size
21.5"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
7 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Anti-glare, 72% colour gamut
Raven black
4.84 kg
VGA , HDMI , DisplayPort , 4 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
Tilt Angle
-5/+30
Swivel Angle
90
Rotation Angle
90
Height Adjustment
110 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management
1 x SuperSpeed USB cable - 1.8 m , 1 x VGA cable - 1.8 m
Power Supply
Internal
21 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Microsoft Windows Vista / 7 / 8 / 8.1
Dimensions & Weight Details
Without stand - width: 51.29 cm - depth: 4.4 cm - height: 30.46 cm - weight: 3.07 kg
Limited warranty - 3 years - carry-in
10 - 80%
Scroll to top
