BT.com
Wishlist
Lenovo ThinkVision T2014 19.5" 1600x900 5ms VGA DVI LED Monitor
Clearance
Last Few Remaining
Price Drop
Price Drop!
Delivery
Standard Due date unavailable
The ThinkVision T2014 features a 19.5" display with built-in power for ease of use. It has 5ms response time, 250 nits brightness and 1000:1 native contrast ratio. With a clean appearance, T2014 has tilt stand, VGA and DVI interface. It's all for your flexible use. Following a tradition of ThinkVision products, ThinkVision T2014 is also respectful to the environment with numerous certifications including Energy Star 6.0, TCO certification, EPEAT Gold and many others.
Lenovo ThinkVision T2014 - LED monitor - 19.5"
LED-backlit LCD monitor - 19.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 75 Hz
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Raven black
47.3 cm x 18.98 cm x 35.21 cm
2.53 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, CSA, TUV GS, VCCI, C-Tick, BSMI, IEC950, NEMKO, NOM, SABS, SASO, CCC, IC, TUV Ergo, PSB, RoHS, ISO 9241-307, KCC, WEEE, JEITA, cTUVus, MEPS, E-Standby, TUV GM, KC, Kvalitet, KUCAS, SONCAP, KEBS, CECP, EMI, DDC-2B/CI, TCO Displays 6.0, UL Environmental SPC Gold, BELLIS, KONCAR, INSM, EPA 6.0, CEL Grade 1, China RoHS, CSM, ISC, TCO Certified Edge 2.0
3 years warranty
Display Type
Diagonal Size
19.5"
Viewable Size
19.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 75 Hz
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Video Bandwidth
205 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, H/V position, colour balance, input select
OSD Languages
Chinese (simplified), English, German, French, Italian, Russian, Spanish, Japanese
HDCP, 72% colour gamut
Raven black
47.3 cm x 18.98 cm x 35.21 cm - with stand
2.53 kg
VGA , DVI-D
Mechanical
Tilt
Tilt Angle
-5/+22
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable - 1.8 m , 1 x DVI cable - 1.8 m
Power Supply
Internal
22 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Microsoft Windows 7 / 8 / 8.1
ENERGY STAR Certified
Limited warranty - replacement - 3 years - carry-in
Scroll to top
