BT.com
Wishlist
Lenovo ThinkVision LT2934z 29" 2560x1080 7ms VGA DVI-D HDMI DisplayPort LED Monitor
Delivery
Standard Due date unavailable
For users looking for a truly unique viewing experience, ThinkVision introduces LT2934z 29-inch panorama display. Its 2560 x 1080 Panoramic display makes multi-tasking and desktop management so much easier. Moreover, its cinema-like ultra-wide AH-IPS display allows for an amazing movie experience from any angle. With sRGB color gamut, it boasts picture quality that is more vibrant and accurate. Apart from packing a wide range of connectivity options, LT2934z sports a best-in-class VoIP solution which greatly simplifies collaboration over the internet. Unique to ThinkVision displays, LT2934z also supports ThinkVision PIP Anywhere software and Keyboard/Mouse One Switch Toggle which allow users to work simultaneously between two PC systems seamlessly and efficiently. To top it all, ThinkVision LT2934z adopts the latest green standards; it's certified EnergyStar 6.0, TUV Green Mark, EPEAT Gold, TCO Display 6.0, TCO Certified Edge 1.2, and UL Environment Gold.
ThinkVision PIP Anywhere is a software solution which enables quick access to LT2934z's picture-in-picture (PIP) / picture-by-picture (PBP) display modes from the desktop.
Lenovo ThinkVision LT2934z - LED monitor - 29"
LED-backlit LCD monitor - 29"
Energy Class
Class B
Energy Consumption per Year
59 kWh
Power Consumption (On mode)
40 W
2 microphones, USB 3.0 hub, FHD camera
Panel Type
AH-IPS
Aspect Ratio
21:9
Native Resolution
2560 x 1080 at 60 Hz
Pixel Pitch
0.2628 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 3000000:1 (dynamic)
Response Time
7 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-I, VGA, DisplayPort
Speakers
Internal
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare
Black with dark metallic bezel
69.92 cm x 23.97 cm x 38 cm
8.3 kg
English / United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
FCC Class B certified, VESA FPMPMI, RoHS, ISO 9241-307, TUV GM, DDC-2B/CI, TCO Displays 6.0, UL Environmental SPC Gold, TCO Certified Edge 1.2
3 years warranty
Display Type
Energy Class
Class B
59 kWh
40 W
Diagonal Size
29"
Viewable Size
29"
Built-in Devices
Panel Type
AH-IPS
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.2628 mm
Pixel Per Inch
96
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
7 ms (grey-to-grey)
Vertical Refresh Rate
30 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
205 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Controls & Adjustments
Brightness, input select
OSD Languages
Chinese (simplified), English, German, French, Italian, Russian, Spanish, Japanese
Picture in picture, picture by picture, HDCP, Infinity Glass, Mobile High-Definition Link (MHL), 72% NTSC (CIE 1931) colour gamut, 100% sRGB (CIE 1931) colour gamut, daisy chain compatible
8.3 kg
Audio
Speakers - stereo - internal
Output Power / Channel
3 Watt
HDMI (HDCP) , DisplayPort (HDCP) , VGA (DB-15) , DVI (HDCP) , 2 x USB 3.0 downstream , 2 x USB 2.0 downstream , Microphone , Headphones
Mechanical
Tilt Angle
-5/+25
Swivel Angle
90
Height Adjustment
110 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, detachable stand
1 x VGA cable - 1.8 m , 1 x DVI cable - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x USB cable - 1.8 m
Power Supply
Internal
50 Watt
Power Consumption Sleep
1.2 Watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 69.92 cm - depth: 23.97 cm - height: 38 cm - weight: 8.3 kg , Without stand - width: 69.92 cm - depth: 5 cm - height: 36.17 cm
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - replacement - 3 years
8 - 80%
Accessories
£9.99
£7.22
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£19.86
£38.70
£52.42
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£59.47
Scroll to top
