BT.com
Wishlist
Lenovo ThinkVision LT2223z 21.5" 1920x1080 5ms VGA HDMI DisplayPort LED Monitor
Delivery
Standard Due date unavailable
For mainstream professionals who demand better productivity, collaboration and manageability, Lenovo presents ThinkVision LT2223z VoIP monitor from its ThinkVision VoIP series. Packed with an integrated FHD webcam, two digital microphones and speakers, LT2223z makes collaboration over the internet simpler and more convenient; and with a built-in USB Hub, it provides better manageability and just an overall distinct user experience. It's designed without compromises, featuring a 21.5-inch FHD LED backlit panel, an array of connectivity options, and also Tiny PC support. To top it all, it meets the latest standards of green certifications, qualified by Energy Star 6.0, TUV Green Mark, EPEAT Gold, TCO Display 6.0, TCO Certified Edge 1.1, and UL Environment Gold.
Lenovo ThinkVision LT2223z - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class A
Energy Consumption per Year
25.1 kWh
Power Consumption (On mode)
17.2 W
USB 3.0 hub, FHD camera
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Speakers
Internal
Display Position Adjustments
Business black
51.26 cm x 21.84 cm x 37.94 cm
5.43 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
MPR II, TUV GS, VCCI, BSMI, GOST, GS, IEC950, NEMKO, NOM, SABS, SASO, TUV S, VESA DPMS, CCC, IC, PSB, RoHS, ISO 9241-307, Green Mark, JEITA, cTUVus, TCO Certified Edge, E-Standby, KC, Kvalitet, EPA, DDC-2B/CI, TCO Displays 6.0, INSM
3 years warranty
Display Type
Energy Class
Class A
25.1 kWh
17.2 W
Diagonal Size
21.5"
Viewable Size
21.5"
Built-in Devices
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, H/V position, input select, VoIP
OSD Languages
Chinese (simplified), English, German, French, Italian, Russian, Spanish, Japanese
HDCP, 72% colour gamut
Business black
51.26 cm x 21.84 cm x 37.94 cm - with stand
5.43 kg
Audio
Speakers - stereo - internal
Output Power / Channel
3 Watt
HDMI , DisplayPort , VGA (DB-15) , USB 3.0 upstream , 2 x USB 3.0 downstream
Mechanical
Tilt Angle
-5/+30
Swivel Angle
90
Rotation Angle
90
Height Adjustment
110 mm
Flat Panel Mount Interface
100 x 100 mm
Stand
1 x USB cable - 1.8 m , 1 x VGA cable - 1.8 m
Mounting Kit
Optional
Power Supply
Internal
24 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Included Software
Display drivers
Dimensions & Weight Details
With stand - width: 51.26 cm - depth: 21.84 cm - height: 37.94 cm - weight: 5.43 kg , Without stand - width: 51.26 cm - depth: 5.64 cm - height: 35.11 cm - weight: 3.53 kg
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80%
Accessories
Lenovo Microsaver Security Cable Lock
Quicklinx: 393T | In Stock
£41.38
£9.99
£6.94
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.78
£36.49
£49.42
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£56.07
Scroll to top
