BT.com
Wishlist
Lenovo ThinkVision LT2013s 19.5"1600 x 900 5MS VGA LED Monitor
Delivery
Standard Due date unavailable
The ThinkVision LT2013s is a light, slim monitor that comfortably manages your workspace. Equipped with LED panel, tilt stand and VGA connectivity, this monitor delivers a reliable performance at an affordable price.
It also supports Tiny PC, third-party Thin Client and Lenovo USB Soundbar with ease.
Lenovo ThinkVision LT2013s - LED monitor - 19.5"
LED-backlit LCD monitor - 19.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900
Pixel Pitch
0.281 mm
Brightness
200 cd/m²
Contrast Ratio
600:1
Response Time
5 ms
Display Position Adjustments
Tilt
Business black
46.7 cm x 16.07 cm x 34.24 cm
2.5 kg
English / United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
FCC Class B certified, CSA, BSMI, GOST, IEC950, NEMKO, NOM, SABS, SASO, VESA FPMPMI, VESA EDID, CB, CCC, PSB, IRAM, RoHS, ISO 9241-307, JEITA, KC, Kvalitet, KUCAS, DDC-2B/CI, BELLIS, INSM
3 years warranty
Display Type
Diagonal Size
19.5"
Viewable Size
19.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900
Pixel Pitch
0.281 mm
Brightness
200 cd/m²
Contrast Ratio
600:1
Response Time
5 ms
Horizontal Viewing Angle
90
Vertical Viewing Angle
50
Backlight Technology
WLED
Controls & Adjustments
Brightness, input select
72% colour gamut
Business black
2.5 kg
VGA
Mechanical
Tilt
Tilt Angle
-5/+22
Flat Panel Mount Interface
100 x 100 mm
Stand
1 x VGA cable - 1.8 m
Mounting Kit
Optional
Power Supply
Internal
17 Watt
Power Consumption Sleep
0.5 Watt
Microsoft Windows 7, Windows 8
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 3 years - carry-in
Accessories
Lenovo Microsaver Security Cable Lock
Quicklinx: 393T | In Stock
£41.38
£10.50
£10.48
£13.51
C2G VGA to Composite PC-TV Video Adapter
Quicklinx: 7CC5 | In Stock
£36.16
Scroll to top
