BT.com
Wishlist
Lenovo ThinkVision LT1713p 17" 1280x1024 5ms VGA DVI LED Monitor
Delivery
Standard Due date unavailable
The ThinkVision LT1713p provides a great ownership experience at an affordable price.
It prides itself on the highest standards for environmental safety and energy, meeting Energy Star 6.0, TUV Green Mark, EPEAT Gold, TCO Display 6.0, TCO Edge 1.2, UL Environment Gold, CEL 1, RoHs and 85% PCC plastic resins; on top of this, it boasts lower energy consumption and reduced environmental impact. It offers VGA and DVI inputs with tilt and lift stand functions for a customised working environment. The LT1713p's stand also is able to support Lenovo's M92p Tiny with its Tiny support bracket. Users looking for a single solution suitable for a variety of business environments will value this versatile monitor.
Lenovo ThinkVision LT1713p - LED monitor - 17"
LED-backlit LCD monitor - 17"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 72 Hz
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Height, tilt
Business black
37 cm x 16.52 cm x 40.57 cm
3.6 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, TUV GS, VCCI, BSMI, NEMKO, NOM, SABS, VESA DPMS, VESA FPMPMI, CCC, IC, TUV Ergo, PSB, RoHS, ISO 9241-307, KCC, WEEE, JEITA, cTUVus, MEPS, E-Standby, GREENGUARD, KC, CECP, CEL, DDC-2B/CI, TCO Displays 6.0, TCO Certified Edge 1.2, EAC, China RoHS, ISC
3 years warranty
Display Type
Diagonal Size
17"
Viewable Size
17"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Video Bandwidth
165 MHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, input select
OSD Languages
English, German, French, Italian, Russian, Spanish, Japanese, Chinese
HDCP, 72% colour gamut
Business black
37 cm x 16.52 cm x 40.57 cm - with stand
3.6 kg
VGA , DVI-D (HDCP)
Mechanical
Height, tilt
Tilt Angle
-3/+22
Height Adjustment
110 mm
Flat Panel Mount Interface
100 x 100 mm
1 x DVI cable - 1.8 m , 1 x VGA cable - 1.8 m
Power Supply
Internal
16 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Microsoft Windows 7, Microsoft Windows Vista, Windows 8, Windows 8.1
ENERGY STAR Certified
Limited warranty - 3 years
8 - 80%
Accessories
Lenovo Microsaver Security Cable Lock
Quicklinx: 393T | In Stock
£41.38
£7.95
£8.90
£12.18
C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL
Quicklinx: 63SL | In Stock
£9.94
£6.00
£8.53
C2G 2m HDMI to DVI-D Digital Video Cable
Quicklinx: 915T | In Stock
£8.43
£56.40
Scroll to top
