BT.com
Wishlist
Lenovo ThinkVision E2323s 23" 1920x1080 5ms VGA DVI LED Monitor
Delivery
Standard Due date unavailable
The Lenovo ThinkVision E2323 monitor meets users all functional needs in both work and home environments. It adopts WLED backlit panel, with wide screen of 1920 x 1080 resolution pixels, which provides Full HD qualification to customers. Its 16:9 aspect is standing for the increasingly popular trend. With built-in VGA + DVI interfaces and tiltable stand, it offers users comfortable usage experience. Compatible with Windows8.1 makes it more flexible for usage. In addition, it is environmentally conscious, meeting the latest green standards including Energy Star 6.0 Certified, TCO 6.0, China Energy Standard Tier1, EPEAT Silver Certification.
Lenovo ThinkVision E2323 - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
200 cd/m²
Contrast Ratio
600:1 / 3000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
Display Position Adjustments
Tilt
Raven black
54.85 cm x 16.72 cm x 39.9 cm
3.55 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
TUV Ergo, DDC/CI, RoHS, ISO 9241-307, TCO '06
3 years warranty
Display Type
Diagonal Size
23"
Viewable Size
23"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
205 MHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
50
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, H/V position, input select, colour temperature
OSD Languages
Chinese (simplified), English, German, French, Italian, Russian, Spanish, Japanese
72% NTSC (CIE 1931) colour gamut, 100% sRGB (CIE 1931) colour gamut
Raven black
3.55 kg
VGA , DVI
Mechanical
Tilt
Tilt Angle
-5/+22
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable - 1.8 m , 1 x DVI cable - 1.8 m
Power Supply
Internal
21 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
ENERGY STAR Certified
Limited warranty - 3 years - carry-in
45 °C
10 - 80%
Accessories
£7.95
£8.90
£12.18
C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL
Quicklinx: 63SL | In Stock
£9.94
£6.00
£8.53
C2G 2m HDMI to DVI-D Digital Video Cable
Quicklinx: 915T | In Stock
£8.43
£56.40
Scroll to top
