BT.com
Wishlist
Lenovo ThinkVision E2223 21.5" 5ms VGA DVI LED Monitor
Delivery
Standard Due date unavailable
The Lenovo ThinkVision E2223s monitor meets users all functional needs in both work and home environments.
It adopts WLED backlit panel, with wide screen of 1920 x 1080 resolution pixels, which provides Full HD qualification to customers. Its 16:9 aspect is standing for the increasingly popular trend. With built-in VGA + DVI interfaces and tiltable stand, it offers users comfortable usage experience. Compatible with Windows Vista, Windows7 and Windows8 makes it more flexible for usage. In addition, it is environmentally conscious, meeting the latest green standards including Energy Star 6.0 Certified, China Energy Standard Tier1, EPEAT Silver Certification.
Lenovo ThinkVision E2223s - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
200 cd/m²
Contrast Ratio
600:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
Display Position Adjustments
Tilt
Raven black
51.45 cm x 16.72 cm x 37.94 cm
3.4 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
RoHS, ISO 9241-307
3 years warranty
Display Type
Diagonal Size
21.5"
Viewable Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
200 cd/m²
Contrast Ratio
600:1
Colour Support
Response Time
5 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
205 MHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
50
Backlight Technology
WLED
Colour Temperature
9300K, 7200K, 6500K
Controls & Adjustments
Brightness, contrast, H/V position, colour balance, input select
OSD Languages
Chinese (simplified), English, German, French, Italian, Russian, Spanish, Japanese
100% (CIE 1931) colour gamut, 72% NTSC (CIE 1931) colour gamut
Raven black
3.4 kg
VGA , DVI
Mechanical
Tilt
Tilt Angle
-5/+22
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable - 1.8 m , 1 x DVI cable - 1.8 m
Mounting Kit
Optional
RoHS, ISO 9241-307
Power Supply
Internal
19 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Limited warranty - 3 years
45 °C
Accessories
Lenovo Microsaver Security Cable Lock
Quicklinx: 393T | In Stock
£41.38
Scroll to top
