BT.com
Wishlist
Lenovo ThinkVision LT2024 20" 1600x900 5ms VGA DVI LED Monitor
Delivery
Standard Due date unavailable
The Lenovo ThinkVision LT2024 20-inch LED-backlit LCD Monitor is an economical display solution for any environment. With a consistently narrow, 16.8 mm bezel, the LT2024 is optimised for multi-monitoring. Tiny PCs, 3rd-party Thin Clients and the Lenovo USB sound bar are supported with ease. For supreme visuals, the LT2024 offers a 16:9 aspect ratio, 1600 x 900 native display resolution, and VGA and DVI connectors. If you need a monitor that offers value for money, mesmerising visuals and strong green values, look no further than the ThinkVision LT2024.
Lenovo ThinkVision LT2024 - LED monitor - 20"
LED-backlit LCD monitor - 20"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900
Pixel Pitch
0.277 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Display Position Adjustments
Tilt
34.74 cm x 16.07 cm x 47.84 cm
3.07 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, CSA, TUV GS, VCCI, C-Tick, BSMI, NEMKO, NOM, SABS, SASO, CCC, IC, PSB, RoHS, ISO 9241-307, JEITA, cTUVus, E-Standby, KC, Kvalitet, KUCAS, SONCAP, KEBS, CECP, TCO Displays 6.0, BELLIS, KONCAR, INSM, EPA 6.0, CEL Grade 1, ISC
3 years warranty
Display Type
Diagonal Size
20"
Viewable Size
20.0"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900
Pixel Pitch
0.277 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
Controls & Adjustments
Brightness
3.07 kg
VGA , DVI-D
Mechanical
Tilt
Tilt Angle
-5/+22
Power Supply
Internal
ENERGY STAR Certified
Limited warranty - 3 years - carry-in
45 °C
10 - 80%
Accessories
£8.41
£9.42
C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL
Quicklinx: 63SL | In Stock
£10.56
£6.00
C2G USB to DVI Adapter Up To 2048 x 1152
Quicklinx: 8H1Y | In Stock
£44.74
C2G 2m HDMI to DVI-D Digital Video Cable
Quicklinx: 915T | In Stock
£8.92
£60.32
Scroll to top
