Click to visit BT.com
BT.com
Wishlist
Lenovo IdeaTab A2107 7" Tablet Cortex A9 16GB Android ICS
4.0*
Quicklinx: 8F53WS00
Mfr#: MA337UK
Gear up for the outdoors with the Lenovo® IdeaTab™ A2107. The 7" form factor makes it easy to carry around and the roll cage protects against bumps and jolts. What's more, the offlline GPS support along with 3G and WiFi connectivity keep you connected, no matter where you are.
  • Dimensions: 122mm (W) x 192mm (H) x 11.5mm (T)
  • Weight: 400g (0.9 pounds)
  • Operating System: Android™ 4 Ice Cream Sandwich
  • Connectivity/Radios: WiFi b/g/n, Bluetooth® 4.0, Professional A-GPS (10-sec lock with 3G)
  • Memory: 512MB
  • Battery: 8 to 10 hours of browsing over WiFi
  • Processor: MTK6575 Cortex A9 1.0GHz
  • Internal Storage: 16GB eMMC
  • Display: 7.0" TN 1024x600, 5-point multi-touch, Bright 350 nit display
  • Ports/Slots: Micro-USB (type AB), Micro-SD card, 3.5mm audio and mic jack
  • Integrated Camera: 2MP rear camera (D-value 3MP) 0.3MP front camera for video chat
Lenovo IdeaTab A2107 - tablet - Android 4.0 - 16 GB - 7"
Tablet
Operating System
Android 4.0
Display
7" TN TFT - LED backlight - 1024 x 600 ( 170 ppi ) - Multi-Touch
Cortex-A9
Processor Clock Speed
1 GHz
Storage
16 GB
RAM
1 GB
Supported Flash Memory Cards
microSD
Wireless Connectivity
802.11b/g/n, Bluetooth 4.0
Camera
2 Megapixel rear + ( 0.3Mpix front camera )
HD Video Recording
720p
Location
GPS
Battery Run Time
Up to 10 hours
12.2 cm x 1.15 cm x 19.2 cm
400 g
Black, matte black
English / United Kingdom
1 year warranty
Tablet
Operating System
Android 4.0
Display
Resolution
Touchscreen
Multi-Touch
VibrantView, glossy, 5-point multi-touch
Cortex-A9
1 GHz
Storage
16 GB
RAM
1 GB - LPDDR2 SDRAM
microSD
Max Supported Capacity
32 GB
Communications
Camera
Rear-facing Camera
2 Megapixel
HD Video Recording
720p
Front-facing Camera
0.3 Megapixel
Location
Receiver
GPS
Multimedia
Supported Digital Video Formats
MPEG-4, H.263, H.264, VP8
Audio
Microphone , stereo speakers
Supported Digital Audio Formats
MP3, MIDI, AMR, OGG, FLAC, APE, ACC, PCM
Expansion and Connectivity
Expansion Slots
1 x microSD
1 x headset , 1 x Micro-USB
Lithium polymer
13.5 Wh
Run Time
Up to 10 hours
Run Time Details
Web browsing over Wi-Fi - up to 10 hours
Black, matte black
Sensors
Ambient light sensor, three-axis accelerometer, G-sensor
Volume control
Power adapter
1 x USB cable
RoHS
12.2 cm
1.15 cm
19.2 cm
400 g
Service & Support Details
Limited warranty - 1 year - carry-in
Customer reviews
Write a review for the Lenovo IdeaTab A2107 7" Tablet Cortex A9 16GB Android ICS here!
Lenovo A2107 Review
Reviewed by Geoff. Review Posted 27/01/2013
Hi All
I have the Lenovo Z575 Laptop. (Lenovo are IBM)
its a really good laptop. so i was looking also for a tablet and found this. and after weighing up the options between Galaxy Tab and IPADs it seemed ludicrous not to try this because you get so much for the money. again it is my first tablet and already have the iphone.
I just couldnt see why i should spend so much money on a tablet with 3G facility when this does it all for £150
comes as 16GB and can have a 32GB exp Card
Has VPN & tethering facility
Robust body work with roll cage
Front and Back Camera
Dual Sim Facility
Back camera 2mg but it is really good
Front facing VGA
It means i can go to a site, have a job sheet sent through via email, with an App installed the customer can sign it on my tablet and using 3G and can email it straight back
Why have a tablet just on WIFI?
My iphone battery is so bad im going to buy the Lenovo p700 mobile phone. looks like ive made the jump to Android
Hope this helps
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Great wee tablet
Reviewed by Anonymous Review Posted 18/07/2013
Very easy to use if you are familiar with android operating system. The sim card slot for 3G connection is just amazing. Would definately recommend this device. Very pleased with my purchase.
  • Overall 5*
  • Ease of use 5*
Reviewed by Alan Graham. Review Posted 08/12/2012
NOTE: This is my first tablet/Android device.
What I think is missing from the sales details are quite important and very hard to find until you have the product in your hands.
Here's what I think needs telling:
A big bonus with the A2017 is it does have WiFi AND 2 sim card slots, one shown as 3G/2G and the 2nd as 2G. Also a space for a microSDHC card. These are hidden under a cover around the rear camera.
Although it has the 3G this is for data cards, it is not a phone. You can use Skype however.
Between the 3G and GPS this unit is excellent when used with Google Maps. Works just with GPS but the map is basic.
I have marked it down a star because it doesn't have the following sensors:
Orientation
Proximity
Temperature
Gyroscope
Magnetic
Pressure
So no compass apps and Google Sky will not work fully because the Accelerometer only allows up and down! BIG LET DOWN, just as well the GPS works so well... It has light and sound sensors.
Will replace my laptop on holidays nicely :)
  • Overall 4*
  • Ease of use 5*
Brilliant Value
Reviewed by richthegasman. Review Posted 05/01/2013
Really good value and delivered fast
  • Overall 4*
  • Ease of use 5*
OK but but 3G can be flaky
Reviewed by Martin. Review Posted 12/05/2013
This is basically a good tablet. The main reasons for marking it down are the problems I and many people have had with using the 3G facility, and the complete lack of interest from Lenovo in solving problems or even acknowledging them.
The screen has good resolution - there are better ones out there, but at a price. It is difficult to read in bright light but fine indoors. That makes the GPS of doubtful use.
Back to the 3G: there are two normal-sized SIM slots, one marked 2G and the other 2/3G. There are a number of menus involved in getting 3G working, not all of which are easy to find, and the manual is useless in helping. Some SIMS seem to work, others not. I have no problems with Three in the UK, whereas SFR in France I never succeeded in getting to work - it told me there was a 3G signal, received and sent texts, but no internet. If 3G is important to the buyer, it is worth looking elsewhere.
Battery life is good at about 8 hours, much less with the 3G SIM turned on.
  • Overall 3*
  • Ease of use 3*
Beware - Lenovo
Reviewed by Paul Gray. Review Posted 09/07/2013
The product was returned to lenovo to repair a small crack to the screen. The tablet was still in useable working order and only 7 months old.
Quoted £180 to replace the screen despite tablet only costing £150 brand new.
We requested tablet be returned without repair as the quote was ludicrous and it was still in working order.
The tablet was however returned from Lenovo with the screen completely smashed and not working at all.
Lesson learned, some large companies are not to be trusted. Poor product, and very very poor company.
  • Overall 1*
  • Ease of use 1*
  • Value for money 1*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
