BT.com
Wishlist
Lenovo 4GB DDR3 1600MHz DIMM 240-pin PC3-12800 Unbuffered Memory Module
Lenovo 4GB DDR3 1600MHz DIMM...
£88.48
27 in stock
£88.48
Add to wishlist
Delivery
Standard 3-5 working days
Adding more memory increases system performance. It allows you to take advantage of the ThinkStation's full potential when working with 3D imaging, digital content creation, multimedia and other memory-intensive applications.
Lenovo - DDR3 - 4 GB - DIMM 240-pin
RAM memory
4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1600 MHz (PC3-12800)
Dual rank, unbuffered
Lead Plating
Gold
3 years warranty
ThinkStation D30 4354; E31 2552, 2553, 2555, 3688, 3690, 3691, 3695; P300 30AH, 30AK
4 GB
Upgrade Type
System specific
DRAM
DDR3 SDRAM
DIMM 240-pin
Module Height (inch)
1.2
Speed
ECC
Chips Organization
X8
Lead Plating
Gold
Compatible Slots
1 x memory - DIMM 240-pin
3 years warranty
Lenovo ThinkStation D30 4354 , Lenovo ThinkStation E31 2552, 2553, 2555, 3688, 3690, 3691, 3695 , Lenovo ThinkStation P300 30AH, 30AK
Lenovo 4GB DDR3 1600MHz DIMM 240-pin PC3-12800...
£88.48
Save on this ideal PC Build kit!
Save £16.90
£113.83
Scroll to top
