BT.com
Wishlist
LaCie XtremKey 32GB USB 3.0 AES 256-bit encryption
Delivery
Standard Due date unavailable
The LaCie XtremKey is strongest, toughest USB key yet. With an impenetrable shell, the LaCie XtremKey is a truly rugged USB key that stands up to the elements. The XtremKey is constructed with zamac, a metal alloy composed of zinc, aluminum, magnesium and copper that's so strong, it can withstand the pressure of a 10-ton truck.
The XtremKey's memory modules are shielded inside of a 2mm casing and sealed with wear-resistant screw threads and a rubber O-ring, which makes it watertight up to 100 meters. In addition, it's resistant to 5-meter drops, fierce heat and bitter cold - it holds up in any environment, no matter where you take it (+200°C / -50°). Equipped with the Hi-Speed USB 2.0 interface, the LaCie XtremKey offers instant compatibility, outstanding transfer speeds and cross-platform convenience to all PC and Mac users. With speeds up to 30MB/s (write) and 40MB/s (read), you don't have to sacrifice performance for protection.
LaCie XtremKey - USB flash drive - 32 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
32 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
Apple MacOS X 10.6, Apple MacOS X 10.7 Lion, Microsoft Windows Vista / XP / 7 / 8, Apple MacOS X 10.8
3 years warranty
USB flash drive
Storage Capacity
32 GB
Hardware Encryption
256-bit AES
Compatibility
Non-specific
Read Rate
Up to 230 MB/s
Interface Type
USB 3.0
Shockproof, waterproof
Key ring
IP68
Limited warranty - 3 years
74 mm
22 mm
57 g
5 °C
35 °C
Scroll to top
