LaCie RuggedKey - USB flash drive - 32 GB - USB 3.0
Standard Due date unavailable
The LaCie RuggedKey is built to withstand accidental drops from heights far above what you'd encounter on your way to the office. Its rubber construction is 100m drop-resistant. That means ultimate protection for your key - and your data - for all of life's little stumbles.
Life's an adventure - and disaster can strike at any turn. With the RuggedKey, the last thing you need to worry about is your data. Heat and cold resistance protect your data in the most extreme of climates, whether you're trekking across a scorching desert or braving the frozen tundra. Furthermore, it's IP-54 certified for resistance to damage from dust and water projection. The RuggedKey is the most portable storage in the LaCie Rugged family yet, and the best on-the-go protection for the real world.
Bigger files need better speed. With the RuggedKey's USB 3.0 interface, you get speeds up to 150 MB/s for daringly fast file transfers. USB 3.0 represents an enormous speed increase from USB 2.0, and best of all, since its backward compatible with USB 2.0, there's never any worry about connectivity.
Hardware rugged, and software secure - the RuggedKey key protects your data from the inside with AES 256-bit encryption. Easily create a password-protected area on the key to securely store all of your confidential information. Ultra-secure AES 256-bit encryption technology means the RuggedKey is secure from the inside out.
LaCie makes it easy to integrate secure cloud storage from Wuala into the RuggedKey, making storing and sharing your files, photos, or videos easier than ever. You get a year of one-to-one storage ratio with Wuala, allowing you to back up your key's contents or double your storage capacity. Even access your files on the go with the Wuala mobile app.
USB flash drive
Interface Type
Storage Capacity
32 GB
Encryption Algorithm
256-bit AES
Microsoft Windows Vista / XP / 7, Apple MacOS X 10.6 - 10.7
USB flash drive
Storage Capacity
32 GB
256-bit AES
Interface Type
53 mm
27 mm
21 mm
30 g
Customer reviews
Write review Read all The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Very nicely designed
Reviewed by Olive Francois on 25/09/2013
This drive has saved me from loosing data a huge number of times. It is always with me, and I never forget to take it home at the end of the day because it's on my car keys! It's really a sturdy little number, and I just wish it came with different colours too.
5* Fast and Reliable
Reviewed by Franklin on 21/05/2014
This RuggedKey gives me the peace of mind I didn't get from other thumb drives. It's very well designed, works great, without any glitches, and is very fast with USB3. Would definitely recommend.
5* excellent product
Reviewed by Boy on 16/11/2013
I've been looking for a good portable drive for my files for a while, and this key seemed like what I needed. The orange rubber casing is a good idea, it gives extra protection to the drive and looks fun. The speeds are great. I'm very pleased with this key in all respects.
5* good product
Reviewed by anonymous on 19/01/2014
After using this thumb drive, with its USB 3.0 interface, it's really hard to "go back" and use anything slower! And the more attached I get to the RuggedKey (I'm still not maxed out in that department), the more I appreciate the orange case that keeps me from losing it..
5* Great Gadget
Reviewed by anonymous on 07/03/2014
I always seem to lose thumb drives, but not this one. It's day-glow bright orange, there is no way that you would lose that even on a messy desk. It's pretty solid, and has survived many drops and falls already. My cat thinks it's a toy and bats it off the desk whenever I forget to put it away.. Amazingly, it still works well.
5* Excellent!
Reviewed by Alana A on 25/07/2014
I really need to use very sturdy USB drives because I'm none too gentle on them, and this little key is just perfect for that - it can take an enormous amount of beating around in my pocket and still work. I also love the fact that it comes bundled with the equivalent amount of Could storage.
5* excellent
Reviewed by anonymous on 04/11/2014
Fast. Reliable. Compact, rugged, and very convenient. Works wonderfully.
5* Awesome
Reviewed by Jacey S on 27/08/2013
Chucked my keys in the wash by accident the other day and found them the next day. Everything, including the RuggedKey, was totally fine after a quick shake dry. After that inadvertent demonstration of the RuggedKey's design I have absolutely no hesitation in recommending this drive to all my friends.
5* Love it
Reviewed by Zane on 27/12/2013
I'm concerned about privacy, and as a result, I used to carry a special, blank USB drive that I could hand over to friends or colleagues to borrow temporarily or to copy files (without handing over sensitive files as well). Now, my RuggedKey has enough room for lots of information, and with Private-Public software, I don't have to worry about accidental disclosure.
5* Excellent
Reviewed by Keira on 19/03/2014
This drive is the perfect little accessory for my new computer - USB3 connection is just amazing. Very fast. I use this key for daily backups, and it's been working very well so far. I am very happy with the purchase.
Scroll to top
