BT.com
Wishlist
LaCie RuggedKey - USB flash drive - 16 GB - USB 3.0
Delivery
Standard Due date unavailable
The LaCie RuggedKey is built to withstand accidental drops from heights far above what you'd encounter on your way to the office. Its rubber construction is 100m drop-resistant. That means ultimate protection for your key - and your data - for all of life's little stumbles.
Life's an adventure - and disaster can strike at any turn. With the RuggedKey, the last thing you need to worry about is your data. Heat and cold resistance protect your data in the most extreme of climates, whether you're trekking across a scorching desert or braving the frozen tundra. Furthermore, it's IP-54 certified for resistance to damage from dust and water projection. The RuggedKey is the most portable storage in the LaCie Rugged family yet, and the best on-the-go protection for the real world.
Bigger files need better speed. With the RuggedKey's USB 3.0 interface, you get speeds up to 150 MB/s for daringly fast file transfers. USB 3.0 represents an enormous speed increase from USB 2.0, and best of all, since its backward compatible with USB 2.0, there's never any worry about connectivity.
Hardware rugged, and software secure - the RuggedKey key protects your data from the inside with AES 256-bit encryption. Easily create a password-protected area on the key to securely store all of your confidential information. Ultra-secure AES 256-bit encryption technology means the RuggedKey is secure from the inside out.
LaCie makes it easy to integrate secure cloud storage from Wuala into the RuggedKey, making storing and sharing your files, photos, or videos easier than ever. You get a year of one-to-one storage ratio with Wuala, allowing you to back up your key's contents or double your storage capacity. Even access your files on the go with the Wuala mobile app.
USB flash drive
Interface Type
USB
Storage Capacity
16 GB
Encryption Algorithm
256-bit AES
Microsoft Windows Vista / XP / 7, Apple MacOS X 10.6 - 10.7
USB flash drive
Storage Capacity
16 GB
256-bit AES
Compatibility
Non-specific
Interface Type
USB
53 mm
27 mm
21 mm
30 g
Customer reviews
Write review Read all The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* great drive
Reviewed by Cooper on 27/08/2013
A friend of mine offered this USB key to me a couple of weeks ago and I'm already addicted! It's a perfect size for carting around music and media. The transfer speed is great, doesn't take long to copy files across. Besides, it looks great, and feels very sturdy.
5* Excellent!
Reviewed by anonymous on 08/09/2013
This key is totally awesome. I've had it for quite a while now, and it works great wherever I need it. Very sturdy yet compact enough to hang on my key-ring. Transfer speeds are very fast. Overall, this is an excellent product.
5* Solid and Fast
Reviewed by anonymous on 22/11/2013
This is a very good drive. The data transfer speeds are excellent. It looks great and feels solid. The main reason I bought this is because I was hoping for a long lasting storage solution for my files, and it feels like I will be using this drive for a while.
5* Exactly what I needed!
Reviewed by Caitlin Hoyt on 14/01/2014
The really cool thing about the encryption feature on this device is that I don't have to commit to an all-or-nothing approach. I can keep my private files in a special encrypted area, and just store files I want to share "out in the open" on the drive. It's a really great solution that keeps everyone happy (and data safe).
5* Great product!
Reviewed by Jada S on 08/10/2013
I've been looking for a solid USB key, and came across this drive - it's perfect for me! 16 GB storage is loads of space, more than I need to be honest. It's now a permanent fixture on my key ring, so convenient. The transfer speeds are very fast with USB3 and the build quality is topnotch.
5* Good device
Reviewed by Jacques on 13/03/2014
What I particularly like about this product is not only being able to encrypt certain files on the device itself, but being able to encrypt them in large enough groups to be efficient (minimizing the amount of work that has to be done to secure data), which in turn can be easily and efficiently transferred to cloud storage.
5* Neat little USB drive
Reviewed by Ace Hannah on 22/10/2014
This is actually one of the few key-ring equipped USB devices where I've actually used the key-ring, mostly because of the protective orange case around the hardware. It makes it easy to find my keys, and of course, just as hard to leave the house without the RuggedKey. I use it all the time, and can't imagine being caught without it.
5* awesome
Reviewed by Callie M on 21/12/2013
I bought this RuggedKey because of its design. I find it very practical. Besides, the bright rubber sleeve makes it hard to lose track of the device if you drop it or leave it on your desk. I use my RuggedKey all the time, and it's the first USB drive I've owned that I haven't lost in more than a year now.
5* awesome
5* Nice and Fast
Reviewed by anonymous on 10/03/2014
The cloud storage that comes with the RuggedKey is a huge benefit, because it gives me an alternative and secure way to store my data. The drive itself comes with encryption software, which allows me to keep my sensitive files private. The speeds are great. I'm very happy with my purchase.
Scroll to top
