BT.com
Wishlist
LaCie Lacie 48TB 8 Bay Thunderbolt 2 Rackmount
LaCie Lacie 48TB 8 Bay Thunderbolt...
£4,327.14
£4,327.14
Add to wishlist
Delivery
Standard Due date unavailable
Fiber Channel DAS has been dethroned. Featuring Thunderbolt 2 speeds of up to 1330MB/s and 48TB in a 1U rackmount size, the LaCie 8big Rack has seized the crown. Video pros, meet the king of storage for 4K workflows.
LaCie 8big Rack Thunderbolt 2 - hard drive array
Hard drive array
Enclosure Type
Rack-mountable - 1U
Total Array Capacity
48 TB
Thunderbolt 2
8 (installed) / 8 (max)
Supported Drives
SATA-600
Built-in Devices
Led panel
Storage Controller
RAID (SATA 6Gb/s) - RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
8 x 6 TB HDD - hot-swap
Apple MacOS X 10.9 or later, Microsoft Windows 7 / Windows 8 or later
AC 120/230 V - 50/60 Hz
Power Redundancy
47.7 cm x 77.2 cm x 4.4 cm
20 kg
5 years warranty
Hard drive array
Enclosure Type
Rack-mountable - 1U
Chassis
Built-in Devices
Led panel
8
Supported Devices / Modules Qty
8
Supported Drives
SATA-600
Storage
48 TB
HDD Array External Interface
Thunderbolt 2
Storage Controller
RAID
Interface Type
SATA 6Gb/s
Max Storage Devices Qty
8
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD - hot-swap
8 x 6 TB
Spindle Speed
7200 rpm
Expansion Bays
8 (total) / 0 (free) x hot-swap - 3.5"
2 x Thunderbolt
Redundant fans, aluminum enclosure, hot-swappable fans
1 x Thunderbolt cable
Software Included
Intego Backup Manager Pro, LaCie Private-Public, LaCie RAID Manager
AES-256
Max Supported Qty
2
Power Redundancy
Power Provided
250 Watt
47.7 cm
77.2 cm
4.4 cm
20 kg
Limited warranty - 5 years
5 °C
10 - 60% (non-condensing)
Sound Emission
50 dB
Scroll to top
