BT.com
Wishlist
  • Description
  • Specifications
  • Bundle deals
  • Accessories
  • Resources
  • Customer reviews
  • Buy used stock
  • Find similar
LaCie Coat 3.5" Hard Disk Sleeve Black
Delivery
Standard Due date unavailable
  • Description
  • Specifications
  • Bundle deals
  • Accessories
  • Resources
  • Customer reviews
  • Buy used stock
  • Find similar
With the LaCie Coat line of bags for your hard drives, you've got a great new way to stylishly protect your favorite gear. Designed by Sam Hecht, the designer behind our popular "Little Disk" line of drives, the Coat bags bring a chic, sophisticated style to technology accessories--one that our customers have come to expect.
One of the most inventive aspects of the LaCie Coat line of bags is its reversible, flexible design. Change your bag from a bubble pattern to sueded fabric, simply by turning it inside out. You'll still get the same level of protection and safety for your hard drive, but you'll be able to customize and change your bag at your leisure--it's like having two bags in one!
A hidden pocket on the inside of the bubble protection helps your LaCie Coat hold even more of your secrets. With the two different sizes in the LaCie Coat line, it's easy to find the one that's right for you. Choose from two sizes, both of which are compatible with most hard drives on the market. LaCie Coat bags are available in gray, red, black, and orange, and whichever one you choose, you can be confident that your LaCie Coat offers superior protection for your drive.
  • Fits : Hard disk 3.5?
  • Internal Dimensions : 3.5? : 210 x 280 mm/ 8.3 x 11 in.
  • Color : Black
  • Material : Neoprene foam
  • Outside : Jersey
  • Inside : Sueded lining
  • Warranty : 1-Year Limited Warranty
Scroll to top
