BT.com
Wishlist
LaCie 6TB Thunderbolt 2 & USB 3.0 7200RPM with Thunderbolt Cable
Delivery
Standard Due date unavailable
With the new d2, LaCie again raised the bar on the industry’s most trusted desktop storage product. Get the job done faster - on any computer - with dual Thunderbolt 2, USB 3.0, and a 6 TB 7200 RPM hard disk. Thanks to its innovative, all-aluminum unibody design, you’ll notice incredibly low vibration and operating noise. With best-in-class speed, versatility, and durability, the new LaCie d2 sets a new standard for desktop storage.
LaCie d2 Thunderbolt 2 - hard drive - 6 TB - USB 3.0 / Thunderbolt 2
Hard drive - external (desktop)
6 TB
Data Transfer Rate
20 Gbps (Thunderbolt 2) / 5.0 Gbps (USB 3.0)
Buffer Size
64 MB
Spindle Speed
7200 rpm
Security lock slot (cable lock sold separately), vibration dampening, aluminium enclosure, fanless design, software encryption, 256-bit AES
Power Source
Included AC adapter
217 mm x 130 mm x 60 mm
1.5 kg
Microsoft Certification
Compatible with Windows 7
3 years warranty
6 TB
Buffer Size
64 MB
217 mm
130 mm
60 mm
1.5 kg
Performance
Interface Transfer Rate
Max Data Transfer Rate
220 MB/s
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x USB 3.0 , 2 x Thunderbolt 2
Power Source
Included AC adapter
Power adapter
Software Included
Intego Backup Assistant, LaCie Private-Public, LaCie Genie Timeline
Microsoft Windows 7 / Windows 8, Apple MacOS X 10.8.5 or later
1 x Thunderbolt cable , 1 x USB 3.0 cable
3 years warranty
Limited warranty - 3 years
Scroll to top
