BT.com
Wishlist
LaCie 6TB 2big Thunderbolt2 USB3 [7200] w cable
Delivery
Standard Due date unavailable
With the redesigned 2big, instead of aiming for incremental, LaCie shot for revolutionary. Its excellent industrial design demolishes the status quo and sets a standard for versatility and reliability. The LaCie 2big also features unbeatable Thunderbolt 2 technology and hardware RAID for sensational performance.
LaCie 2big Thunderbolt 2 - hard drive array
Hard drive array
Total Array Capacity
6 TB
USB 3.0, Thunderbolt 2
2 (installed) / 2 (max)
Storage Controller
RAID RAID 0, 1, JBOD
Hard Drive
2 x 3 TB HDD - hot-swap
Apple MacOS X 10.6 or later, Microsoft Windows 7 / Windows 8
AC 120/230 V - 50/60 Hz
10.9 cm x 13 cm x 21.7 cm
3 kg
Hard drive array
Chassis
2
Supported Devices / Modules Qty
2
Storage
6 TB
HDD Array External Interface
Storage Controller
RAID
RAID Level
RAID 0, RAID 1, JBOD
Storage Controller (2nd)
Data Transfer Rate
420 MBps
Hard Drive
HDD - hot-swap
2 x 3 TB
Spindle Speed
7200 rpm
Expansion Bays
2 (total) / 0 (free) x hot-swap
2 x Thunderbolt , 1 x USB 3.0
Aluminum enclosure
1 x Thunderbolt cable , 1 x USB cable
Software Included
Genie Backup Manager Pro, Intego Backup Manager Pro, LaCie Desktop Manager, LaCie Private-Public
AES-256
External power adapter
Power Provided
60 Watt
10.9 cm
13 cm
21.7 cm
3 kg
Scroll to top
