BT.com
Wishlist
LaCie 5TB Porsche Design 3.5" USB 3.0 Grey
Delivery
Standard Due date unavailable
Accelerate Your Backup with USB 3.0
With the P'9233's USB 3.0 interface, you'll be able to get the job done faster than ever before. Speeds up to 5Gb/s allow you to transfer a 700MB video file in just under 7 seconds. Back up your photos, exchange audio and video files with your friends, or make sure that your important files are kept safe. With the P'9233, the possibilities are endless.
Porsche Design Form, LaCie Function
LaCie worked with Porsche in 2003 and it resulted in one of the most popular hard drives that's still talked about today. With the P'9233, the exclusive and timeless shape returns, with solid, reliable hardware that's sure to last for years. You can use it anywhere and be confident that you're getting superb performance.
Safe, Strong, and Aluminum
With 5mm of solid aluminum casing surrounding the disk inside, the P'9233 keeps your data solidly protected. LaCie and Porsche Design worked together to combine form and function-resulting in a drive that looks great no matter where you take it.
Designed for Your Mac
The P'9233 was designed especially for Mac computers, and features a stylish, sophisticated aluminum finish that matches your new Mac. Plus, it's Time Machine compatible so that you can seamlessly back up to the drive using Mac's built-in software.
Seagate - hard drive - 5 TB
Hard drive - external ( desktop )
5 TB
Power Source
Included AC adapter
5 TB
Power Source
Included AC adapter
Scroll to top
