BT.com
Wishlist
LaCie 500GB Porsche Design P'9220 USB 3.0 2.5" Mobile Drive
Delivery
Standard 3-5 working days
The Ultimate Blend of Design and Performance
The LaCie Porsche Design P'9220 mobile hard drive is more than just a place to store your files-it's a collaboration between one of the most renowned design firms in the world and LaCie. With the P'9220, we've combined speed, design, and technology to result in a different breed of mobile drive.
Porsche Design Form, LaCie Function
LaCie first partnered with Porsche Design in 2003 to produce one of the most iconic and enduringly popular external hard drives on the market. Since then the two companies have worked closely to create products that blend flawless functionality and pure design. The luxury brand and the leading technology company complement each other, with technical influence from LaCie, together with an exclusive and timeless shape presented by Porsche Design.
Accelerate Your Backup with USB 3.0
With the P'9220's USB 3.0 interface, you'll be able to transfer files faster than ever before-a 700MB video file in just under 7 seconds! You can back up your photos, exchange audio and video files with your friends, or make sure that your important files are kept safe. With the speed of USB 3.0, the possibilities are endless. And with capacities up to 1TB, you've got the storage capacity to hold all of your files.
Safe, Strong, and Aluminum
Safe, Strong, and Aluminum Porsche Design is known worldwide for their sophisticated, timeless creations, and the P'9220 is no exception. With 3mm of strong aluminum casing surrounding the drive inside, you can be sure that your data is solidly protected. LaCie and Porsche Design worked together to combine form and function-resulting in a mobile drive that looks great (and works great)-no matter where you take it.
User-friendly Software Suite Included
  • Automatic Backup: Easy setup and automatic worry-free backup for both PC and Mac computers.
  • Password Protection: With LaCie Private-Public software built-in, it's easy to make sure that your files are secure and protected, no matter where you go.
  • Secure Online Storage: 10GB of Wuala Online Storage included for one year to securely store and share your data online.
  • 40% Energy Savings: Automatic Eco mode lowers the power consumption by up to 40% when not in use, increasing the battery life of your notebook or laptop.
  • Capacity: 500GB
  • Interface : USB 3.0 port (USB 2.0-compatible)
  • Interface Transfer Rate : USB 3.0 : up to 5Gb/s
  • USB 2.0 : up to 480Mb/s
  • Size : 71 x 130 x 18 mm / 2.8 x 5.1 x 0.7 in.
  • Weight : 270 g / 9.5 oz.
  • System Requirements : Computer with a USB 2.0 or USB 3.0 port**
  • Latest version of Windows® XP, Windows Vista®, Windows 7 / Mac OS X 10.5, 10.6
  • Check www.lacie.com/usb3mac for USB 3.0 Mac compatibility
  • Minimum free disk space: 600MB recommended
  • Box Content : LaCie Porsche Design P'9220
  • USB 3.0 cable (USB 2.0-compatible)
  • Quick Install Guide
  • Complete Software Suite:
  • LaCie Private-Public, Backup Assistant, Eco Mode*, Wuala
  • Comments : *1TB (Terabyte) = 1000GB. 1 GB = 1,000,000,000 bytes. Total accessible capacity varies depending upon operating environment (typically 5-10% less).
  • ** For optimal performance, the drive must be connected to a USB 3.0 host port. Calculations are based on average write time. Transfer rates vary slightly from one drive to another.
  • *Up to 40% energy savings with automatic standby (1W vs. 1.7W). May vary from one drive to another.
  • Warranty : 2-Year Limited Warranty
LaCie Porsche Design P'9220 - hard drive - 500 GB - USB 3.0
Hard drive - external ( portable )
500 GB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Password authentication, automatic backup
Power Source
USB bus
7.1 cm x 13 cm x 1.8 cm
270 g
2 years warranty
500 GB
USB 3.0
7.1 cm
13 cm
1.8 cm
270 g
Performance
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0
Power Source
USB bus
Software Included
LaCie Backup Assistant
Apple MacOS X 10.6, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5
1 x USB 3.0 cable - external
2 years warranty
Service & Support Details
Customer reviews
Write review Read all The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Sturdy, high capacity drive
Reviewed by Alannah on 27/09/2011
An excellent drive, reliable and with excellent build quality. 500GB is more than enough for all my files, backup and music. The aluminum enclosure is well designed: it's solid and helps eliminate the heat too. The drive is always with me. It has survived lots of miles in my backpack while I'm riding my bike. And it just works flawlessly!
5* Easy, Fast, Portable.
Reviewed by Aiden on 15/06/2012
I bought this drive about half a year ago. It's fast, easy to carry around, and very durable. I use it every day for backup, and it's great for that purpose. Very handy.
5* Great product!
Reviewed by Mayra on 30/08/2012
I've had an external drive connected to my laptop before and found that continual access to the drive would drain my battery life far too quickly. Now that I have this Porsche drive, I can set the power saving mode and extend the life of the drive and my laptop battery.
5* Excellent Product
Reviewed by Ella on 15/12/2012
I've recently bought this drive and I'm very pleased with it. The solid aluminium casing helps it remain cool and it's very quiet. I've set it up to automatically power down when I know I won't be using my computer so hopefully it'll help prolong the life of the drive.
5* As advertised
Reviewed by Bert on 10/04/2013
This drive is great to use, and smooth to handle. I bought it in first place because of its design. It's very nice and well thought out. The speeds are great. The drive is quiet. And it's even easy on the battery of your laptop with the Eco mode.
5* I love it
Reviewed by Brayden on 06/11/2012
I'm a junior designer and I just started working at a creative agency. I use this drive to carry my work around and to transfer stuff between computers. It's been a bit of a lifesaver because the network at work is not very fast. It's an excellent drive, love it!
5* Excellent!
Reviewed by Warren on 23/06/2013
I was looking for a new portable drive, and this little Porsche Design really fit the bill. I love the metal casing and the stylish design, it looks really amazing. Apart from the design, the drive is fast and quiet. Overall, I'm very happy with this thing.
5* Very Pleased
Reviewed by Anonymous on 07/08/2011
I've bought this hard drive to use as a backup device for my PC. It's been working great so far. No errors, fast transfer speed, great encryption feature and easy backup software. Love the Porsche design. Needless to say, I am most pleased with this product.
5* So far so good
Reviewed by Miles on 08/03/2012
I love this drive. I've been using it for over 3 months now, and it's been working perfectly. It's fast, solid, and stylish. Great unit. And reasonable price given the quality.
5* Very nice portable drive
Reviewed by Kyle on 19/05/2012
This is a pretty impressive little drive. I love the speeds it gets with USB 3. It's also backward compatible with USB 2. The data encryption works well. The design and the build quality is outstanding! I highly recommend giving this drive a shot.
Scroll to top
