BT.com
Wishlist
LaCie 4TB d2 Quadra USB 3.0 eSATA 3Gb/s & FireWire 800 [7200]
Delivery
Standard Due date unavailable
With the USB 3.0 5 Gb/s interface, the LaCie d2 Quadra hard disk is the ideal tool for creative professionals who need both fast speeds and large storage capacity. It features 7200 rpm drives with a minimum of 32 MB cache for the best performance and seek times, so it can handle the most resource-intensive applications. Best of all, it can achieve speeds up to 130 MB/s in USB 3.0.
LaCie d2 Quadra USB 3.0 - hard drive - 4 TB - FireWire 800 / USB 3.0 / eSATA-300
Hard drive - external (desktop)
4 TB
Spindle Speed
7200 rpm
Power Source
Included AC adapter
60 mm x 168 mm x 183 mm
1.7 kg
Microsoft Certification
Compatible with Windows 7
3 years warranty
4 TB
60 mm
168 mm
183 mm
1.7 kg
Performance
Data Transfer Rate Details
Serial ATA: 115 MB/s , FireWire 800: 85 MB/s , USB 3.0: 130 MB/s , USB 2.0: 35 MB/s
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x eSATA-300 , 2 x FireWire 800 , 1 x USB 3.0
Power Source
Included AC adapter
Power adapter
Software Included
LaCie Setup Assistant, LaCie Desktop Manager, LaCie Backup Assistant
Microsoft Windows Vista / XP / 7, Apple MacOS X 10.6 or later, Apple MacOS X 10.5
Vertical stand
1 x eSATA cable - external , 1 x IEEE 1394b cable - FireWire 800 (9-to-9 pin) - external , 1 x USB 3.0 cable - external
Limited warranty - 3 years
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* excellent drive with good software package
Reviewed by Hugo on 30/07/2014
I looked at several other options for encrypting files, but they all seemed complicated, certainly when compared with the Private–Public solution from LaCie that comes with this drive. Getting started and up to speed with the software was a snap, and the fact that nobody has the password to my device but me gives me peace of mind.
5* Very good drive
Reviewed by Jenna on 07/05/2014
Excellent drive. Have no issues at all, works great. The quality of the enclosure is very solid. The drive itself is fast and very quiet.
5* Reliable
Reviewed by Cherry G on 20/06/2014
I have two of these drives and I use them as backup drives for my photo and video archives. They are fast, sturdy and reliable. I haven't experienced any issues with either of them.
5* Excellent Drive
Reviewed by anonymous on 22/10/2014
Love a good bit of gear, and this drive is certainly one of those items. It sits beautifully on its stand, taking up very little desk space, and runs quietly, and quickly delivering data as I need it. I've never had a hiccup with it, and I am thoroughly pleased.
5* Great Product
Reviewed by Serge on 20/05/2014
I have a set of these drives on my desk and use them almost constantly. They are quiet, vibration free, and seem to work without any glitches. The best part is that they come with heaps of connections and all the parts are an excellent standard and built to withstand heavy use.
5* Great Drive!
Reviewed by Cain W on 01/11/2014
The d2 Quadra is a great package, the hardware is of an excellent quality and cables are top quality too. The drive has USB 3.0, Firewire 800, and eSATA connections, and they provide cables for each. Cables are the first thing to go on any drive, and providing new ones in the box illuminates lots of potential issues. The drive itself is great - fast, silent, reliable.
5* Works Great, No Problems
Reviewed by Sheila Kimble on 08/10/2014
I've purchased this drive when I ran out of storage space on my 1TB backup drive. This is a quiet and efficient backup unit, it has a number of different cables and transfer options and it works great. It's very fast (I have a USB 3 port on my laptop). Started it up without any problems, it's pretty much plug and play.
Scroll to top
