BT.com
Wishlist
LaCie 4 TB / Thunderbolt2 & USB 3.0 / 7200RPM With Cable
Delivery
Standard 3-5 working days
With the new d2, LaCie again raised the bar on the industry's most trusted desktop storage product. Get the job done faster - on any computer - with dual Thunderbolt 2, USB 3.0, and a 4 TB 7200 RPM hard disk. Thanks to its innovative, all-aluminum unibody design, you'll notice incredibly low vibration and operating noise. With best-in-class speed, versatility, and durability, the new LaCie d2 sets a new standard for desktop storage.
LaCie d2 Thunderbolt 2 - hard drive - 4 TB - USB 3.0 / Thunderbolt 2
Hard drive - external (desktop)
4 TB
Data Transfer Rate
20 Gbps (Thunderbolt 2) / 5.0 Gbps (USB 3.0)
Buffer Size
64 MB
Spindle Speed
7200 rpm
Security lock slot (cable lock sold separately), vibration dampening, aluminium enclosure, fanless design, software encryption, 256-bit AES
Power Source
Included AC adapter
217 mm x 130 mm x 60 mm
1.4 kg
Microsoft Certification
Compatible with Windows 7
3 years warranty
4 TB
Buffer Size
64 MB
217 mm
130 mm
60 mm
1.4 kg
Performance
Interface Transfer Rate
Max Data Transfer Rate
220 MB/s
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x USB 3.0 , 2 x Thunderbolt 2
Power Source
Included AC adapter
Power adapter
Software Included
Intego Backup Assistant, LaCie Private-Public, LaCie Genie Timeline
Microsoft Windows 7 / Windows 8, Apple MacOS X 10.8.5 or later
1 x Thunderbolt cable , 1 x USB 3.0 cable
3 years warranty
Limited warranty - 3 years
Scroll to top
