BT.com
Wishlist
LaCie 2TB Porsche Design P'9230 USB 3.0 3.5" Desktop Drive
Delivery
Standard Due date unavailable
The LaCie Porsche Design P'9230 is a breed of desktop hard drive, a perfect blend of form and function. It's the product of collaboration between one of the most renowned design firms in the world and LaCie. The P'9230 lets you transfer files faster than ever with USB 3.0 performance, and has the capacity to hold all of your files. It also features a striking LED that both indicates power and lends sophisticated elegance.
LaCie first joined forces with Porsche design in 2003 to produce one of the most iconic and enduringly popular external hard drives on the market. Since then the two companies have worked closely to create products that blend flawless functionality with pure design. The luxury brand and the leading technology company complement each other, with technical influence from LaCie, together with an exclusive and timeless shape presented by Porsche Design.
With the P'9230's USB 3.0 interface, you'll be able to get the job done faster than you ever imagined-you can transfer a 700 MB video file in just under 7 seconds! With USB 3.0 speed, you can back up your photos, videos, and music files, and even quickly exchange them with friends or colleagues-with minimal wait time.
The P'9230 protects your files with 5 mm of aluminum casing surrounding the drive inside. This solid armor protects your data, gives the drive sophisticated substance, and even helps to dissipate heat. These properties help to protect the hard disk and prolong its lifespan. LaCie and Porsche design worked together to combine form and function-resulting in a desktop hard drive that looks great on your desk.
LaCie Porsche Design P'9230 - hard drive - 2 TB - USB 3.0
Hard drive - external (desktop)
2 TB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Password authentication, automatic backup
Power Source
Included AC adapter
12 cm x 19 cm x 3.8 cm
1 kg
2 years warranty
2 TB
USB 3.0
12 cm
19 cm
3.8 cm
1 kg
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0 - 9 pin USB Type B
Power Source
Included AC adapter
Power supply
Software Included
LaCie Backup Assistant
Apple MacOS X 10.6, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5
1 x USB 3.0 cable - USB Type A to B - external
2 years warranty
Customer reviews
Write review Read all The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Very pleased
Reviewed by Kimberly on 02/02/2012
I purchased this Porsche drive to expand my storage capacity. Installation was quick, everything is very simple. The drive is equipped with USB 3.0. It works well. When inactive, the drive switches to the power saving mode. I've enjoyed using it so far.
5* Excellent, well designed product!
Reviewed by Caelin on 27/08/2011
I was looking for a sold, reliable hard drive for backup and for storing photos and video, when I came across this LaCie model. This drive has an absolutely outstanding design and is completely hassle free. You simply plug it in and it works. The software suite that comes with the drive is good. The transfer speed is great. It's exactly what I needed.
Reviewed by Anonymous on 27/08/2011
5* Great desktop hard drive
Reviewed by Anonymous on 10/08/2011
This drive works exactly as expected and quietly does what it's supposed to do. It doesn't overheat, even after hours of operation it only gets slightly warm to the touch. The aluminum enclosure is very well built and does great job of dissipating heat from the drive. The speed is good, the design is awesome. I'm very satisfied overall.
5* Loving it!
Reviewed by Owen on 30/09/2011
Excellent external drive. Lots of storage space, nice design, looks great next to my screen. I love the solid aluminum casing and the fact that it allows to protect data with a password. I have two very bored teenage boys, so it doesn't hurt to add a little extra security.
5* Good model
Reviewed by Jeffrey on 22/11/2011
The drive is very compact in comparison to my other desktop hard drives. The design is wonderful, and the aluminum casing is sturdy. The drive has little rubber feet which prevents it from sliding on the desk. It's supplied with optional backup software. USB 3.0 interface allows for very high transfer speed. Bottom line: I love it.
5* No Problems So Far
Reviewed by Lisa on 24/02/2012
This is an excellent drive. It's plug-and-play and works exactly as advertised. I couldn't be happier with USB 3.0 transfer speed. The design and the build quality are just awesome. Data encryption software and eco mode feature are a nice bonus. I'd recommend.
5* Excellent!
Reviewed by Adalie on 15/03/2012
I've been using this Porsche drive for over three months now. Happy with everything so far - its ergonomics, design, silent operation, and fast speed. It's compact and discreet too. I love it!
5* Great hard drive.
Reviewed by Mallory on 14/05/2012
This drive is very well designed and works well. I have only had it for a couple of months, and it does what it says on the box. USB 3.0 is a good feature, and it's backward compatible with USB 2.0. The drive is very quiet, simple to use and runs pretty cool.
5* Good drive
Reviewed by Amalie on 28/09/2012
I was looking for an external drive for backup – something that looks nice and has high quality hardware. This Porsche drive met these demands. I connect it to my computer via USB 3.0 (recently got a new work computer with a USB 3.0 port – very nice!), and it works wonderfully.
Scroll to top
