BT.com
Wishlist
LaCie 250GB Rugged SSD Thunderbolt 64MB 2.5" Portable Hard Drive
LaCie 250GB Rugged SSD Thunderbolt...
£191.42
£191.42
Add to wishlist
Delivery
Standard Due date unavailable
Deadlines rule our world. When digital storage is critical for your project, it had better be as fast and reliable as you are. From the desktop to the badlands, it has to connect to any computer, deliver more than enough speed for the most demanding applications, and protect data against any threat.
LaCie Rugged Thunderbolt - solid state drive - 250 GB - USB 3.0 / Thunderbolt
Solid state drive - external (portable)
250 GB
Data Transfer Rate
10 Gbps (Thunderbolt) / 5.0 Gbps (USB 3.0)
Shock resistant, water resistant, rugged pocket-sized design, password authentication, dust-proof, automatic backup, software encryption, 256-bit AES
Power Source
USB bus, Thunderbolt bus
89 mm x 140 mm x 24 mm
280 g
3 years warranty
250 GB
Internal Drive Interface
SATA 6 Gb/s
89 mm
140 mm
24 mm
280 g
Performance
Interface Transfer Rate
Max Data Transfer Rate
387 MB/s
Expansion & Connectivity
1 x USB 3.0
Power Source
Software Included
LaCie Backup Assistant, LaCie Private-Public
Apple MacOS X 10.6 or later, Microsoft Windows Vista / XP / 7 / 8
Protective cover
1 x Thunderbolt cable - integrated , 1 x USB 3.0 cable - external
IP54
Limited warranty - 3 years
Scroll to top
