BT.com
Wishlist
LaCie 1TB Rugged Thunderbolt USB 3.0 SSD
Delivery
Standard Due date unavailable
Universal Connectivity
Don't let your project get derailed by external drive/computer incompatibility. With both USB 3.0 and Thunderbolt interfaces, the LaCie Rugged is a perfect match for your Mac® and PC. And because USB 3.0 is backwards compatible, you can connect it to any standard computer on the planet. The LaCie Rugged is also fully bus-powered through the included USB 3.0 and Thunderbolt cables. Its portability and interfaces make it the must-have sidekick to a new Mac or Ultrabook™.
No-Compromise Speed
Get lightning-fast transfer speeds on Mac and PC thanks to the USB 3.0 and Thunderbolt interfaces. With the SSD version, the LaCie Rugged delivers up to 385MB/s – the fastest bus-powered product ever**. The HDD version performs up to 110MB/s, a 35% improvement over FireWire 800. Back up and transfer mountains of data in a fraction of the time. Enjoy noticeably more responsive photo library browsing
Complete Data Protection
Protecting your data is vital to meeting your deadline, and disaster can strike at any moment. That's why the LaCie Rugged is MIL-compliant for superior data protection from accidental drops up to 1.2 meters (4 feet). Whether it falls off your desk or out of the pocket of your safari jacket, you're confident that your data is still accessible. The SSD version goes a step further for the ultimate in resilience against vibration and shock. Both versions are tough enough to be shipped for reliable delivery to clients or partners. Included software even protects your files from prying eyes with AES 256-bit encryption.
LaCie Rugged Thunderbolt - solid state drive - 1 TB - USB 3.0 / Thunderbolt
Solid state drive - external (portable)
1 TB
Encryption Algorithm
256-bit AES
Data Transfer Rate
10 Gbps (Thunderbolt) / 5.0 Gbps (USB 3.0)
Shock resistant, water resistant, password authentication, dust-proof, rugged, automatic backup, software encryption, 256-bit AES
Power Source
USB bus, Thunderbolt bus
89 mm x 140 mm x 24 mm
280 g
3 years warranty
1 TB
256-bit AES
Internal Drive Interface
SATA 6 Gb/s
89 mm
140 mm
24 mm
280 g
Performance
Interface Transfer Rate
Max Data Transfer Rate
387 MB/s
Expansion & Connectivity
1 x USB 3.0 - 9 pin USB Type B , 1 x Thunderbolt
Power Source
Software Included
LaCie Backup Assistant, LaCie Private-Public
Apple MacOS X 10.6 or later, Microsoft Windows Vista / XP / 7 / 8
Protective cover
1 x Thunderbolt cable - integrated - 37 cm , 1 x USB 3.0 cable - USB Type A to B - external - 50 cm
IP54
Limited warranty - 3 years
Scroll to top
