BT.com
Wishlist
LaCie 1TB Porsche Design P'9220 USB 3.0 2.5" Mobile Drive
LaCie 1TB Porsche Design P'9220 USB...
£66.15
30 in stock
£66.15
Add to wishlist
Delivery
Standard 3-5 working days
The Ultimate Blend of Design and Performance
The LaCie Porsche Design P'9220 mobile hard drive is more than just a place to store your files-it's a collaboration between one of the most renowned design firms in the world and LaCie. With the P'9220, we've combined speed, design, and technology to result in a different breed of mobile drive.
Porsche Design Form, LaCie Function
LaCie first partnered with Porsche Design in 2003 to produce one of the most iconic and enduringly popular external hard drives on the market. Since then the two companies have worked closely to create products that blend flawless functionality and pure design. The luxury brand and the leading technology company complement each other, with technical influence from LaCie, together with an exclusive and timeless shape presented by Porsche Design.
Accelerate Your Backup with USB 3.0
With the P'9220's USB 3.0 interface, you'll be able to transfer files faster than ever before-a 700MB video file in just under 7 seconds! You can back up your photos, exchange audio and video files with your friends, or make sure that your important files are kept safe. With the speed of USB 3.0, the possibilities are endless. And with capacities up to 1TB, you've got the storage capacity to hold all of your files.
Safe, Strong, and Aluminum
Safe, Strong, and Aluminum Porsche Design is known worldwide for their sophisticated, timeless creations, and the P'9220 is no exception. With 3mm of strong aluminum casing surrounding the drive inside, you can be sure that your data is solidly protected. LaCie and Porsche Design worked together to combine form and function-resulting in a mobile drive that looks great (and works great)-no matter where you take it.
User-friendly Software Suite Included
  • Automatic Backup: Easy setup and automatic worry-free backup for both PC and Mac computers.
  • Password Protection: With LaCie Private-Public software built-in, it's easy to make sure that your files are secure and protected, no matter where you go.
  • Secure Online Storage: 10GB of Wuala Online Storage included for one year to securely store and share your data online.
  • 40% Energy Savings: Automatic Eco mode lowers the power consumption by up to 40% when not in use, increasing the battery life of your notebook or laptop.
  • Capacity: 1TB
  • Interface : USB 3.0 port (USB 2.0-compatible)
  • Interface Transfer Rate : USB 3.0 : up to 5Gb/s
  • USB 2.0 : up to 480Mb/s
  • Size : 71 x 130 x 18 mm / 2.8 x 5.1 x 0.7 in.
  • Weight : 270 g / 9.5 oz.
  • System Requirements : Computer with a USB 2.0 or USB 3.0 port**
  • Latest version of Windows® XP, Windows Vista®, Windows 7 / Mac OS X 10.5, 10.6
  • Check www.lacie.com/usb3mac for USB 3.0 Mac compatibility
  • Minimum free disk space: 600MB recommended
  • Box Content : LaCie Porsche Design P'9220
  • USB 3.0 cable (USB 2.0-compatible)
  • Quick Install Guide
  • Complete Software Suite:
  • LaCie Private-Public, Backup Assistant, Eco Mode*, Wuala
  • Comments : *1TB (Terabyte) = 1000GB. 1 GB = 1,000,000,000 bytes. Total accessible capacity varies depending upon operating environment (typically 5-10% less).
  • ** For optimal performance, the drive must be connected to a USB 3.0 host port. Calculations are based on average write time. Transfer rates vary slightly from one drive to another.
  • *Up to 40% energy savings with automatic standby (1W vs. 1.7W). May vary from one drive to another.
  • Warranty : 2-Year Limited Warranty
LaCie Porsche Design P'9220 - hard drive - 1 TB - USB 3.0
Hard drive - external (portable)
1 TB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Password authentication, automatic backup
Power Source
USB bus
7.7 cm x 13 cm x 1.8 cm
260 g
2 years warranty
1 TB
USB 3.0
7.7 cm
13 cm
1.8 cm
260 g
Performance
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0
Power Source
USB bus
Software Included
LaCie Backup Assistant, LaCie Private-Public
Apple MacOS X 10.6, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5
1 x USB 3.0 cable - external
Other bundles
LaCie 1TB Porsche Design P'9220 USB 3.0 2.5" Mobile...
£66.15
Half Price Hard Drive Case with portable hard drives
Save £4.99
£71.14
Customer reviews
Write review Read all The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Very well buit
Reviewed by Fiona on 05/08/2012
I don't know much about computer hardware but with other external drives I had I've been concerned about their plastic enclosures. They always seemed too flimsy. This drive on the other hand is very solid. It has a nice aluminum casing that looks great and feels sturdy. I'm much more comfortable taking this drive with me when I travel.
5* Nice little HD!
Reviewed by Chase on 09/11/2012
I have to say I generally turn a blind ear to claims of bigger, better, and faster, because that's what advertising seems to be all about. But I set my Porsche P'9220 to copying large files through a USB 3.0 connection, the speed of the process got my attention right quick! Copying files is easily twice as fast, and probably more compared to my old drive (USB 2, three y.o.)!
5* Nice design. Great performance.
Reviewed by Ace L on 07/01/2014
I got this drive a couple of weeks ago and I'm really pleased with it. It has a really nice metal case, and looks great. Setting it up was easy, it works seamlessly with the Windows backup software. Transferring all my data initially took some time, all subsequent backups were much faster.
5* Nice drive!
Reviewed by Wade on 07/08/2011
I'm very satisfied with this hard drive. It has a nice well designed aluminum enclosure, which makes the drive look very classy. The installation was easy. The transfer speed is good. The drive works silently and doesn't get hot. Overall, this is a great product, I would highly recommend it!
5* Reliable
Reviewed by Anthony on 30/09/2011
This is a quality external drive with excellent performance. I've been using for a couple of months now and it has never let me down. It's very practical, compact, with a strong aluminum enclosure. The drive works perfectly with different types of computers. Would recommend without hesitation!
5* Excellent product
Reviewed by Jennifer on 03/04/2012
I bought this to use as a travel hard drive with my laptop, and it works admirably. It's fast, quiet, well built, and with a large storage capacity. It has a small form factor, so I just toss it in my laptop bag along with my computer. The enclosure is made of solid aluminum. It looks great and protects the disk better than any plastic would.
5* Great Item
Reviewed by Lucas on 01/06/2012
This drive is really good. Very fast, and comes with data encryption software. The drive is perfect for transportation, solid, and with plenty of storage space. It has also got a very nice design.
5* Excellent Drive
Reviewed by Marcel on 25/11/2012
I've got a wifi router that allows me to run a drive off it, so I set it up with one of these. I store all my music and videos on this drive, so I can easily share the files across the local network and stream content to other devices.
5* Awesome Hard Drive
Reviewed by Alina on 10/02/2013
A well built and reliable drive. 1 TB capacity is plenty for my work and personal backups. I've been using it for a couple of months, it's quiet and fast. Very happy with this Porsche, just what I was looking for.
5* Excellent kit, good price
Reviewed by Corinne on 27/10/2011
This is a great portable drive, excellent combination of quality and style. It comes with an almost complete kit: a USB cable and a choice of backup and encryption software. I'm also pleased with its performance.
Scroll to top
