BT.com
Wishlist
LaCie 1TB Porsche Design 2.5" USB-C Portable Hard Drive
Delivery
Standard 3-5 working days
The LaCie Porsche Design Mobile Drive welds advanced technology from LaCie with immaculate style from Porsche Design. Thanks to USB-C, this mobile drive works with any computer - the one you own and the one you might have on your wish list. And with amazing transfer speeds, you can drag and drop files and perform backups quickly.
What's in the box
  • LaCie Porsche Design Mobile Drive - hard drive
  • USB-C cable
  • USB to USB type C adapter
  • Software
LaCie Porsche Design Mobile Drive - hard drive - 1 TB - USB 3.1 Gen 1
Hard drive - external (portable)
1 TB
USB 3.1 Gen 1 - USB-C
Data Transfer Rate
5.0 Gbps (USB 3.1) / 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
Aluminium enclosure, LED access indicator
Power Source
USB bus
84 mm x 128 mm x 10 mm
193 g
1 TB
USB 3.1 Gen 1
84 mm
128 mm
10 mm
193 g
Performance
Interface Transfer Rate
Expansion & Connectivity
1 x USB 3.1 Gen 1 - 24 pin USB-C
Power Source
USB bus
Software Included
LaCie Backup Assistant, LaCie Private-Public, LaCie Desktop Manager Eco Mode
Microsoft Windows 7, Apple MacOS X 10.5 or later
1 x USB-C cable - external , 1 x USB to USB-C adapter - external
Scroll to top
