BT.com
Wishlist
Kyocera TASKalfa 265ci A4 Legal Colour Laser Printer
Delivery
Standard Due date unavailable
This high-quality compact multifunction device is the perfect partner for small and medium-sized work groups who demand professional-quality color and black and white documents and who won't compromise on reliability. Document workflow can be easily optimized with dedicated program keys. In addition, KYOCERA's open software development platform, HyPAS, allows the device to be customized to meet the exact needs of your business. The exceptional durability of KYOCERA's long-life components minimizes downtime, costs and the environmental impact.
Kyocera TASKalfa 266ci - multifunction printer ( colour )
Fax / copier / printer / scanner
Fax Type
Super G3 - plain paper
Printing Technology
Laser ( colour )
Max Copying Speed
Up to 26 ppm (mono) / up to 26 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 9600 x 600 dpi (mono) / up to 9600 x 600 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Fax Resolutions
200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
Scanning
600 x 600 dpi
Display
4.3"
Original Size
A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper
Standard Media Capacity
300 sheets
Max Media Capacity
1300 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
PC Connection Availability
PC Connection
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, HyPAS (Hybrid Platform for Advanced Solutions)
AC 230 V ( 50/60Hz )
51.4 cm x 55 cm x 60.3 cm
38.7 kg
Environmental Standards
ENERGY STAR Qualified , Blue Angel
Fax Type
Plain paper
Printing Technology
Laser - colour
Display Diagonal Size
4.3"
Display Features
Touch screen
PC Connection
AirPrint Enabled
Standard Memory
1024 MB
Max Supported Memory
2048 MB
Supported Flash Memory
SD Memory Card, SDHC Memory Card
Copying
Max Copying Speed
Grey Scale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Modes
Text, photo, text and photo
Automatic Duplexing
Copying Features
2 on 1, 4 on 1, ID Card Copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, KPDL3, PCL XL, PDF 1.7, XPS
Automatic Duplexing
First Print Out Time B/W
9 sec
First Print Out Time Colour
10.5 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Grey Scale Depth
8 bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Fax Resolutions
Fax Machine Features
One Touch Dialing
100 station(s)
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
70 x 148 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm)
300 sheets
Max Media Capacity
1300 sheets
50 sheets
150 sheets
Input tray - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 50 sheets size: 70 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , ADF - 50 sheets size: 140 x 210 mm - Legal (216 x 356 mm) weight: 50 g/m² - 120 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 26 ppm ( A4 ) - B/W , Printing: up to 26 ppm ( A4 ) - colour , Copying: up to 26 ppm ( A4 ) - B/W , Copying: up to 26 ppm ( A4 ) - colour , Scanning: up to 35 ipm ( A4 ) - B/W , Scanning: up to 25 ipm ( A4 ) - colour
1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
SSL, IPsec
Operating System Support
UNIX, Linux, Apple Mac OS X 10.5 or later, MS Windows
464 Watt
Power Consumption Standby
79 Watt
Power Consumption Sleep
3 Watt
Warm Up Time
29 sec
First Copy Out Time B/W
10 sec
First Copy Out Time Colour
12 sec
Consumables Included
1 x Cartridge ( black ) - up to 5000 pages , 1 x Cartridge ( cyan ) - up to 2500 pages , 1 x Cartridge ( yellow ) - up to 2500 pages , 1 x Cartridge ( magenta ) - up to 2500 pages
TUV, ISO 9001, GS, ISO 14001, ISO 7779
Blue Angel Compliant
51.4 cm
55 cm
60.3 cm
38.7 kg
Sound Emission
27.6 dBA (idle) / 48.6 dBA (operating)
Scroll to top
