BT.com
Wishlist
Kyocera M2035DN Mono Multifunction Printer
Delivery
Standard Due date unavailable
These ECOSYS A4 MFPs have been designed for busy work groups looking for a productive device to support them in their daily office routine. They have a shortened time to first page and produce up to 35 pages per minute when copying or printing. They can also quickly scan and copy double-sided originals with their powerful 50-sheet document processor. These multifunctionals can be complemented with optional paper feeders anytime to meet your needs of today and tomorrow.
Kyocera ECOSYS M2035dn - multifunction printer (B/W)
Printer / copier / scanner
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
50000 pages
Recommended Monthly Volume
2000 pages
Max Printing Speed
Up to 35 ppm
Max Printing Resolution
Up to 1800 x 600 dpi
Scanning
600 dpi
Original Size
140 x 210 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper
Standard Media Capacity
300 sheets
Max Media Capacity
800 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
PC Connection Availability
PC Connection
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network, Kyocera ECOSYS Technology
AC 230 V (50/60Hz)
49.4 cm x 43 cm x 44.8 cm
18 kg
Environmental Standards
ENERGY STAR Qualified, EPEAT Silver
Printing Technology
Laser - monochrome
50000 pages
2000 pages
Display
5 lines
PC Connection
AirPrint Enabled
Standard Memory
512 MB
Max Supported Memory
1536 MB
Supported Flash Memory
SD Memory Card
Copying
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Modes
Text, photo, text and photo
Automatic Duplexing
Copying Features
2 on 1, 4 on 1, ID Card Copy, Sort, Multiple Copy
Printing
Max Printing Speed
Up to 35 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, KPDL3, PCL XL, PDF 1.7, XPS, EPSON LQ-850, IBM Proprinter X24E, Lineprinter
Automatic Duplexing
First Print Out Time B/W
7 sec
Scanning
Automatic Duplexing
Optical Resolution
600 dpi
Grayscale Depth
8-bit
Document & Media Handling
Min Original Size
140 x 210 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
70 x 148 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Plain paper
300 sheets
Max Media Capacity
800 sheets
50 sheets
150 sheets
Input tray - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Bypass tray - 50 sheets size: 70 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , ADF - 50 sheets size: 140 x 210 mm - Legal (216 x 356 mm) weight: 50 g/m² - 120 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 35 ppm (A4) - B/W , Scanning: up to 35 ipm (A4) - B/W , Scanning: up to 14 ipm (A4) - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
LDAP, SSL, IPsec
Operating System Support
UNIX, Linux, Apple MacOS X 10.4 or later, MS Windows
AC 230 V (50/60Hz)
439 Watt
Power Consumption Standby
65 Watt
Power Consumption Sleep
3.7 Watt
Warm-Up Time
20 sec
First Copy Out Time B/W
6.9 sec
Consumables Included
1 x Cartridge (black) - up to 3600 pages
TUV, ISO 9001, GS, ISO 14001, ISO 7779
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
49.4 cm
43 cm
44.8 cm
18 kg
Sound Emission
27.6 dBA (idle) / 51.5 dBA (operating)
Accessories
Kyocera Toner Cartridge - 1 Black - 7200 pg
Quicklinx: 84WN | In Stock
£79.78
Scroll to top
