BT.com
Wishlist
Kyocera FS-C8025MFP A3 Colour Laser Multifunction Printer
Kyocera FS-C8025MFP A3 Colour Laser...
£2,804.66
£2,804.66
Add to wishlist
Delivery
Standard 1-3 working days
The ECOSYS FS-C8525MFP A3 multifunction color printer offers all the benefits of a professional document management solution for workgroups and small offices. Featuring Hybrid platform for advanced solutions, easy-to-operate touch screen and a range of paper-handling options, all in a well-designed compact package. Cost-efficient and eco-friendly offices will appreciate Kyocera's unique ECOSYS technology which increases operating life, reduces environmental impact, cuts printing costs and ensures reliability.
Kyocera FS-C8525MFP - multifunction printer (colour)
Printer / copier / scanner
Copier Type
Digital
Printing Technology
Laser (colour)
Max Copying Speed
Up to 25 ppm (mono) / up to 25 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Scanning
600 x 600 dpi
Original Size
98 x 148 mm (min) - A3/Ledger (297 x 432 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
140 x 182 mm (min) - A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
Media Type
Envelopes, plain paper
Standard Media Capacity
600 sheets
Max Media Capacity
1600 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
280 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
PC Connection Availability
PC Connection
USB 2.0, Gigabit LAN, USB host
Office Machine Features
Save to USB flash drive, scan to e-mail, scan to folder, scan to network, HyPAS (Hybrid Platform for Advanced Solutions)
AC 230 V (50/60Hz)
59 cm x 59 cm x 74.8 cm
80 kg
Environmental Standards
ENERGY STAR Qualified
Copier Type
Digital
Printing Technology
Laser - colour
Display Features
Touch screen
PC Connection
Standard Memory
1.5 GB
Max Supported Memory
2 GB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Automatic Duplexing
Copying Features
2 on 1, 4 on 1
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PCL 5c, KPDL3, PCL XL, PDF, XPS
Automatic Duplexing
First Print Out Time B/W
10 sec
First Print Out Time Colour
12 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Grey Scale Depth
8 bit
Document & Media Handling
Min Original Size
98 x 148 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
140 x 182 mm
Max Media Size
A3/Ledger
Min Media Weight
60 g/m²
Max Media Weight
256 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), Folio (216 x 330 mm)
600 sheets
Max Media Capacity
1600 sheets
100 sheets
280 sheets
Paper cassette - 500 sheets - A3 (297 x 420 mm) weight: 60 g/m² - 256 g/m² , Bypass tray - 100 sheets size: 98 x 148 mm - A3/Ledger (297 x 432 mm) weight: 60 g/m² - 256 g/m² , ADF - 50 sheets size: 140 x 182 mm - A3/Ledger (297 x 432 mm) weight: 45 g/m² - 160 g/m² , Output tray - 250 sheets , Job separator tray - 30 sheets
Speed Details
Printing: up to 25 ppm (A4) - B/W , Printing: up to 25 ppm (A4) - colour , Copying: up to 25 ppm (A4) - B/W , Copying: up to 25 ppm (A4) - colour , Printing: up to 13 ppm (A3) - B/W , Printing: up to 13 ppm (A3) - colour , Copying: up to 13 ppm (A3) - B/W , Copying: up to 13 ppm (A3) - colour , Scanning: up to 40 ipm (A4) - B/W , Scanning: up to 40 ipm (A4) - colour
1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
Operating System Support
UNIX, Linux, Apple MacOS X 10.4 or later, MS Windows
AC 230 V (50/60Hz)
597 Watt
Power Consumption Standby
125 Watt
Power Consumption Sleep
0.9 Watt
Warm Up Time
45 sec
First Copy Out Time B/W
11.7 sec
First Copy Out Time Colour
13.6 sec
Consumables Included
1 x Cartridge (black) - up to 3000 pages , 1 x Cartridge (cyan) - up to 1500 pages , 1 x Cartridge (magenta) - up to 1500 pages , 1 x Cartridge (yellow) - up to 1500 pages
TUV GS, ISO 9001, ISO 14001
59 cm
59 cm
74.8 cm
80 kg
Sound Emission
35 dBA (idle) / 49 dBA (operating)
Scroll to top
